3982 mm to feet and inches - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
About 13 feet 3/4 inches.
Posted on Apr 15, 2014
Convert 940mm x 1170mm x 240mm into feet and inches
3 feet 1.01 inches by 3 feet 10.07 inches by 9.45 inches.
One inch is 25,4 mm and one foot is 12 inches.
Jan 14, 2017 | Office Equipment & Supplies
How to fix the error concerning barometer
1 atm = 29.92 in Hg (inches of mercury)
1 atm = 760 mm Hg (millimeters of mercury)
1 atm = 1013.20 millibars
1 atm = 14.7 psi (pounds force per square inch)
1 atm = 1013.20 hPa (hectopascals) ...
Unit Number Required Data Entry Elevation Of Barometer ASL Meters Feet Observed Barometer Reading Inches Hg Millibars
Nov 04, 2016 | The Watches
Convert mm to inches
About 72.87 (close to six feet one inch).
Mar 10, 2014 | Office Equipment & Supplies
Avalanche minimum rotor thickness
Rear Brakes JC5/JH5 Utility Only
Rotor Discard Thickness* .............................. 28.50 mm (1.122 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 29.0 mm (1.142 inch)
Rotor Thickness-new .................................... 30.0 mm (1.181 inch)
Rotor Maximum Allowable Lateral Runout ................. 0.05 mm (0.002 inch)
Rotor Maximum Allowable Scoring ........................ 1.50 mm (0.059 inch)
Rotor Maximum Allowable Thickness Variation ........... 0.025 mm (0.001 inch)
Rear Brakes JH6
Rotor Discard Thickness * ............................. 27.50 mm (1.082 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 28.0 mm (1.102 inch)
Rotor Thickness-new .................................... 29.0 mm (1.141 inch)
Nov 12, 2013 | 2002 Chevrolet Avalanche
110MM os how many inches 300M are now many feet?
1 inch = 2.54 cm = 25.4 mm
1 foot = 12 inches = 30.48 cm
110 mm / 25.4 mm = 4.33 inches
300 m * 100 cm/m = 30000 cm / 30.48 cm/foot = 984.25 feet
Jul 18, 2011 | Office Equipment & Supplies
3.05x3.92 (metric) what is this in feet and inches
3.05 meters = 10.007 ft, or 120.08 in
3.92 meters = 12.86 ft, or 154.33 in
3.05 meters x 3.92 meters = 10.007 ft x 12.86 ft = 128.69 ft^2 (feet squared)
= 120.08 in x 154.33 in = 18531.946 in^2 (inches squared)
if you meant millimeters then
3.05 mm = .01 ft, or .12 in
3.92 mm = .01286 ft, or .15433 in
3.05 meters x 3.92 meters = .01 ft x .01286 ft = .0001286 ft^2 (feet squared)
= .12 in x .15433 in = .018531946 in^2 (inches squared)
1 meter = 3.2808399 feet
1 meter = 39.3700787 in
1 millimeter = 0.0032808399 feet
1 millimeter = 0.0393700787 inches
Jun 19, 2011 | Office Equipment & Supplies
What is 615m lengh in inchers.330m width 700m hieght. can you tell me the inches?
(All values below are rounded to the nearest tenth)
615 meters = 24212.6 inches
330 meters = 12992.1 inches
700 meters = 27559.1 inches
The area of this box would be 8,669,335,548,609.2 inches^3 (cubed). Since this is an absurdly large number, I'm going to assume that you meant "m" to mean millimeters. The proper abbreviation of millimeters is "mm."
615 mm = 24.2 inches
330mm = 13 inches
700mm = 27.6 inches
The area of THIS box would be 8,683 inches^3 (cubed) or 723.6 cubic feet.
Incidentally, this is not a problem with a calculator, but a problem done using a calculator.
Apr 12, 2011 | Office Equipment & Supplies
How to calculate the weihgt of circular cones
(1/3) x pi x radius2 x height x density = pounds
where ::
radius = radius of base in inches
density = pounds per cubic inch
height = height in inches
(or you could use feet, meters, cm, mm for radius & height and use kg for density or wahtever units you wish as long as the units are consistent)
Charlie
Feb 22, 2011 | American Standard Plumbing
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
How many mm are in a inces & a foot.
25.4mm = one inch. Google "metric conversion" and you will find a number of sites with online tables and converters.
Apr 27, 2010 | Watches
16 people viewed this question
k24674
jasbo
jasbo
