Question about Microwave Ovens
How to replace fuse in GE JVM1750SPSS - Microwave Ovens
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
I have a microwave JVM3670SK06  ge what amp fuse does it use
I found a good site to find parts for the microwave. It has the fuse for $7. GE WB27X10388 Line Fuse PartSelect
Here is another search form different sellers.
WB27X0007 GE Microwave Ceramic Fuse Replacement
The fuse info
Specifications:
  • 250 Volt.
  • 15 Amp.
  • Type: Fast Blow.
  • Approx. 1.25"L.
Oct 18, 2015 | GE Microwave Ovens
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
GE PROFILE PURCHASED 2006 RUNS BUT NO HEAT MICRO/CONV MODEL JEB1095BB
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 10, 2009 | GE JVM1630 Microwave Oven
Ge microwave blows fuses, replaced fuse after hiltonjug's excellent advice and the next day it went through another one, doesn't sound good. Thanks, Jeff
have you checked/replaced the : HI-Voltage capacitor,the HI-Voltage Diode, and checked the unit for current draw while its in operation?these are three main components of fuse failure
Sep 06, 2009 | GE JVM1330BW/WW Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
No power-inadvertently left on empty GE je1160wmc
Hi. the inverter in your unit has failed. have it replaced asap. It is possible that the In-line fuse has blown as well. you can access this fuse by removing the cover. the fuse is locate din the inverter sector, in line with the power cord. If this fuse is not blown, replace the inverter assembly.
Aug 27, 2009 | GE Microwave Ovens
GE MICROWAVE FUSE REPLACEMENT
i have a galanz microwave i need to replace the fuse and i dont know wht to buy
Dec 21, 2007 | Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
