Ainsworth apsm-460 power supply - Computers & Internet
What is error code 460 on a Ricoh Aficio SP C811Dn
SC 460 The problem may just be dirty separation components that a cleaning may resolve. The code refers to the following:
High voltage power: Separation bias output error
The status of the power pack is checked every 20 ms. This SC is issued
if the EGB detects a short in the power pack 10 times at D(ac).
1. Replace the high-voltage supply cable.
2. Replace the high-voltage power supply unit
3. Replace the IOB.
Aug 26, 2014 | Ricoh Aficio Office Equipment & Supplies
Oki mb 460 doesnt work!
Are there any lights at all? could be the hv power supply or the engine board.
Dec 07, 2013 | Oki Electric Industry MB460...
Need a new remote control for a windchaser fan. Model # is OCWR116. Serial Number is 0014192. You can call me at my cell at 402-322-1645. Thank you, Al Allen, Maintenance Director at the...
Unfortunately, Al, Windchaser has been out of business for about 6+ months and finding replacement parts are like looking for a needle in a haystack.There may be a substitute for it, but it would mean reprogramming or replacing the receiver in the unit. In my searches, I have not been able to find a universal replacement for AC units. However, there is one place you might try
http://www.remotecontrols.com/ You will definitely need the correct model number of the hand held remote, when search for it.
I hope this helps you and thanks for choosing FixYa.
FYI - You may need to change your cell phone number after posting it on here. As thousands of folks now have it.
Aug 22, 2011 | Windchaser Heating & Cooling
I need instructions on how to unhhok the old power supply and install a different one.
You can get a power supply here (and other places).
http://www.power-on.com/atx12vhp300bt.html
You can get one at 300, 350, 460, and 550 watts. This is just one site, the power supply can be found at other sites.
Here are sites that have instructions on replacing a ATX power supply.
http://www.fonerbooks.com/r_power.htm
http://tech.blorge.com/Structure:%20/2009/01/03/how-to-replace-a-desktop-pc-power-supply-unit-psu-tutorial-with-pictures/
Apr 14, 2011 | HP Pavilion Media Center TV M8400f Pc PC...
I just installed the palit gtx 460 sonic 2gb and am getting no display output. I am running iBUYPOWER Gamer Power 563D3 Phenom II X4 965(3.4GHz) 4GB DDR3 500GB HDD CapacityWindows 7 Home Premium 64-bit. I...
The fact that your old Palit GT220 worked shows that your system components are NOT faulty.
The Palit GTX 260 requires the following
1) A PCI-Express 2.0 comliant motherboard.
2) Two 6 pin PCI-Express power connectors.
3) Minimum 450W or greater system power supply.
Lets break this down a little
1) You already have a motherboard that supports this card so no problem there.
2) I am unsure whether your power supply has two 6 pin PCI-Express power connectors, it should have one though and the GTX 460 package should have a molex to 6 pin PCI Express power adapter that you can use for the other.
3) Now it comes to the power supply itself. Currently your system has a 480W power supply. Through some calculating it seems that a system of this spec should have at least a 550W power supply. This means that your current power supply is 70W out. This may be why you get no signal, there is enough power for allthe other comonents but not enough left over for your GPU.
Before you go out and buy a new power supply just check that both 6 pin power connecters are firmly clipped in. If after that the card still doesn't power up then I suggest you purchase a Cooler Master Exteme power plus 550W or greater power supply.
Jan 07, 2011 | Palit Microsystems Palit GTX 460 Sonic 2GB...
Asus geforce 460 - there are two conectors fo external power supply, which one to connect?
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
You need to connect both of them.
Happy Gaming
damnor01
Oct 26, 2010 | ASUS ENGTX460 DirectCU TOP2DI768MD5...
When i plug it in, the screen doesnt work, and it beeps twice.
Power requirements of this video card exceeds what your power supply can provide. You need to upgrade your power supply to a minimum of 500W with 12v dual rail
Oct 20, 2010 | MSI N460GTX Cyclone 768D5OC GeForce GTX...
Not working after wrong settings
If your main power is 220Vac and it is set in 115Vac. It could be you actually fried your power supply.
Here is the reason, in common power supply after the rectifier diode when it is set in 115Vac, its circuit acts as a voltage doubler, its mean in its downsteams it actually uses around 220Vdc. And when you uses it in 220Vac it will connect directly as a rectifier.
When you set it in 115Vac and plug in 220Vac. In its downstream it could be in 440Vdc, then its an overvoltage everything that can't compensate will be damaged.
Hope I give you some info.
May 31, 2009 | Vantec iON 2 VAN-460N (VAN460N) 460-Watt...
Wrong voltage rating
Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is:
a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine.
or
b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460.
so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
Hope that helps, and thank you.
Feb 16, 2009 | Jackson 25 in. TempStar HH Free-standing...
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
