Question about GTCO CalComp Drawing Board III 34600 Graphic Tablet
TABLET 34600 DRIVES NEEDED TO LOAD - GTCO CalComp Drawing Board III 34600 Graphic Tablet
Where is a tutorial to learn how to load micro sd cards and flash drives for tablet use?
http://www.howtogeek.com/201980/how-to-mount-a-flash-drive-on-your-android-device/
Apr 01, 2015 | Coby Kyros MID8120-4G 8" 4 GB Tablet -...
My tablet usb will not work
Try plugging in the USB cable between the tablet and the USB port of a PC. The PC should recognise and install the correct driver software.
On the Tablet you need to choose between "debugging" and memory flash disk. Choose the Memory flash disk option on the screen.
The Tablets internal drives will then appear as drives on the PC if successful.
Some PC's cannot install the correct driver software, so you will have to download a generic android one from the Internet.
Apr 01, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Proscan tablet does not load just shows start up screen
Usually a factory reset or firmware reload is needed to fix that. You can lose all data when you do so.
Feb 28, 2014 | Proscan 8" Tablet with 4GB Memory
How do i load dstv drifta on acer a1 tablet
how do i load dstv drifta on acer ai tablet
Feb 07, 2014 | Acer Tablets & eReaders
POLAROID TABLET PMID709 WILL NOT CHARGE
How old is tablet , maybe new battery is needed ???? Is there power at the wall plug your using ???? Sometimes it's as easy as the plug , !!M the charger your using May be bad , do you know how to use a voltage meter to test if there s power coming from it to your tablet ?? More info is needed on this ??
Dec 01, 2013 | Polaroid Tablets & eReaders
Pattern unlock android
do a factory reset most of the time this works it take it back to the orignal state when you bought it
it should up load all the needed files to restart it with out ant troubles
Aug 23, 2013 | Iview Cyberpad 756TPC Tablet
I think that the II and the III is the same.
(sorry for my bad english)
I have the II and I have the user's manual, but my scanner it's death...
Mar 26, 2008 | GTCO CalComp Drawing Board III 34600...
GTCO CalComp Drawing Board III 34600 Graphic Tablet Logo
Top GTCO Computers & Internet Experts
David Payne
David Payne
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
