Question about Exercise & Fitness
Error 01 Horizon T101-4 - Exercise & Fitness
E21 keeps appearing on console on horizon adventure 4 treadmill
If you wish to get some details about treadmill error codes and troubleshooting ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 14, 2016 | Horizon Exercise & Fitness
How to solve E1 error code on a horizon t101.
check the speed sensor. Clean the dust on its surface if any. or align the speed sensor or replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Feb 29, 2016 | Horizon Exercise & Fitness
Error code 321
Sep 23, 2015 | Horizon Exercise & Fitness
Code 701 06 comes up
I have a T91 and first had the Lube Belt error. After lubing the belt and upon turning the unit on while holding the Stop (Not necessary according to instructions by horizon but I did it while powering up anyway) button down, the 701 06 was momentarily displayed. The unit then displayed the Lube Belt warning again. Lemme know if you hear anything, I am working on it.
Burt
Nov 17, 2013 | Horizon Exercise & Fitness
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Horizon Model 3.2E LCD showing MILE EP 5101
THis is a reboot error. The upper control board is not loading properly. It might flash temporarily but If it stays on the upper control board will need to be replaced.
www.twincityrepair.com
Feb 24, 2009 | Horizon Exercise & Fitness
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
