Question about Behringer DD400 - Digital Stereo Delay/Echo Effects Pedal
Behringer DD400 blinking light - Behringer DD400 - Digital Stereo Delay/Echo Effects Pedal
What caused my Behringer PMP 6000 to short out? LED lights are blinking, and both fans in the back stop working.... Thank you...
I had the same thing happen and it ended up being a diode in the power supply. This video is what got me through it https://youtu.be/BATUad5an4Q
Mar 07, 2015 | Behringer Pmp6000 Powered Mixer 1600w 1600...
Why does the power light blink on the b115 speakers
Your best bet would be to contact Behringer directly. Here is the link- BEHRINGER FEEDBACK
Feb 01, 2015 | Music
Th lights on rare of the speaker are blinking no sound
I had two of these units fail exactly the same way. The amplifier assembly is the failing part.
If it's out of warranty, then you will need to order a replacement. Don't bother with Behringer support, they aren't helpful. I recommend a place called The Tone Garage. They have said they can order replacement amplifier assemblies in about 4 weeks.
Here is the link:
Eurolive B115D Powered PA Speaker
Apr 23, 2014 | Behringer Eurolive B115D Powered PA...
Behringer b212 active speaker no sound except weird high pitch feed back and power light won't go on.
i would check the power supply and the power amp! There must be a short in there.Honestly,it needs a well complete check by a pro! Thank's! Serge Lavallee!
Apr 22, 2014 | Behringer Eurolive B212A Speaker
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try: http://www.eserviceinfo.com/index.php?what=search2&searchstring=behringer+pmh+3000
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
Flashing 88
I think there is nothing wrong with it, it flashes probably because you still not confirm that "8" bank of effects is selected. When it blinks showing the number you just press the selector (the same you use to select what effect you want) once and it should stay on.
Jan 19, 2014 | Behringer Audio Players & Recorders
My vt999 wont work the blue and red lights just blink
you have either a mechanism jammed or something wrong in the power supply bad--don't keep trying as sooner or later you will have smoke.
Dec 22, 2012 | Behringer VT999 Vintage Tube Pedal
On my Behringer UB1202 mixing board none of the inputs work. I plug headphones into the headphone jack to monitor. Neither dynamic nor condenser microphones work (with phantom power enabled when...
Does your computer Recognize the mixer. and to answer your question honestly Behringer is Junk they make cheap knock offs of really expensive products. but see if your computer recognizes it and if not i sugguest taking it back
May 13, 2011 | Behringer XENYX 1202 Premium 12-Input...
Behringer XENYX 2442FX Mixer. The power light does not come on, The +48V does come on. The solo light blinks Constancy. No sound. I checked the fuses, they seem to be OK. any ideas on what wrong
You have likely lost one, probably the +15 volt power supply... This is possibly a shorted component or a short on the circuit board causing this. It takes some skills at troubleshooting to find this. Sometimes using a thermal imaging camera will show hot spot... other times you have to search with a millivoltmeter. The rude solo light is driven by an op amp that uses both polarities of 15 volts and to turn it on it pulls negative... Hence I suspect the +15 is missing.
Nov 05, 2010 | Behringer XENYX 2442FX Mixer
Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Mar 31, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer DD400 - Digital Stereo Delay/Echo Effects Pedal Logo
47 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
