Question about Chevrolet 1995 Chevrolet S10/s15/sonoma Radio
1995 chevrolet s10 5 speed manual transmission will not move in any gear except 4th gear what is the problem?
Vehicle will not move in any gear except 4th gear it is a 5 speed manual transmission what could be the problem?
SOURCE: 1995 CHEVROLET LUMINA TRANSMISSION PROBLEM
ground wire off somewhere that will cause trans problems and dash light problems
Posted on Feb 18, 2009
  • 34 Answers
SOURCE: 1995 Chevy Silverado Transmission
It should be a chevy T5
Posted on Mar 14, 2009
Rickygittins
  • 715 Answers
SOURCE: transmission
www.tvmadeez.com/tvinstadj.php
This is great info, need to pressure check trans to properly set up trans. for long life, check it out
Be cool
Posted on May 03, 2009
csmock132
  • 4669 Answers
SOURCE: 1999 Chevy Tracker - Manual Transmission Issues
Sounds like a bad countershaft bearing. The trans will need removed and disassembled to fix it.
Posted on Jun 02, 2009
dmfixit
  • 226 Answers
SOURCE: transmission- when puting shifter in any any gear, wiil not move when hot, but when it is cold wil move.
possibly a weak pump inside the transmission /rebuild or replace .
Posted on Nov 19, 2009
1988 Toyota 5 speed manual w series transmission will only engage 4th gear. Why
Did you check the transmission fluid level? if it is OK, then you need to have a transmission specialist look into this.
Feb 27, 2015 | 1988 Toyota Pickup
My chevrolet aveo won't intermittently move from 2nd to 3rd or 4th gear, and have to reduce speed and move back down to 2nd and try again ....notice it more if trying to move up the gears quickly
This transmission is electronically shifted via solenoids controlled by a computer, so you need to have that tested for fault codes that may be in memory.
Jun 07, 2012 | 2010 Chevrolet Aveo
I have a 1995 Buick Century 6 cyl. The transmission shifts smoothly and into 4th gear but when I get to about 55 mph it shifts back into 3rd gear by itself and won't go back into 4th gear. What is...
Fourth gear in your vehicle doesn't exist. What feels like a fourth gear is the torque converter locking up. The lockup lockup is controlled by a solenoid in the side pan of the transmission, and the solenoid is controlled by the ECM (electronic control module) in response to several pressure, temperature and speed sensors etc. To determine which component is the problem you'll need a professional transmission mechanic with the proper diagnostic equipment.
Jun 28, 2011 | 1995 Buick Century
Ford transmission wines in 1st 2nd 3rd revers, no
It is a 5 speed manual transmission? If it is noisey in all gears except for 4th, then the problem is countershaft bearings.
Apr 16, 2010 | 1995 Ford Aerostar
1990 Buick LeSabre shifts late
sounds as if you should service the transmission they wil replace oil and filters and gaskets etc ..
Sep 07, 2009 | 1995 Chevrolet Caprice Classic
Manual transmission issue
the greabox is worn out
Oct 04, 2017 | 1990 Geo Tracker
1995 Nissan XE Pickup Transmission Problems-PLEASE HELP
your luck as with mine is not good. thought I had a bad bearing, after droping the tranny and seperating the housing, I have a broken counter shaft. after looking for another with no luck, the tranny shop informed me that was common for these transmissions. parts are expensive, to rebuild would cost aprox.$800.00 or more. the main cause is the front bearing is supported in alum. causing shaft to move which first takes out the bearing, then the strain snaps the shaft. taking out all gears except 4th and only moves while in 4 wheel drive.
Apr 13, 2009 | Nissan Pickup Cars & Trucks
95 GMC Sierra 4L60E will not shift down to 1st or up to 4th.
no power stuck in 3rd gear electric shop unless youve burnt it up good luck...www.TransmissionGarage.com
Jan 28, 2009 | 1995 GMC Sierra
Chevrolet 1995 Chevrolet S10/s15/sonoma Radio Logo
27 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
D. E. Hev
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
