On my fax machine ricoh-1700L code appear 0-02H
Switch on the machine giving code 0-02H
5 Suggested Answers
SOURCE: I'm looking for error codes for the ricoh 5510 fax machine
service code 0544
Posted on Apr 04, 2008
  • 393 Answers
SOURCE: no fax tone giving if this fax mode only
Using "on hook" you should hear a dial tone, if you have one then dial a known good fax number. It could also be in manual receive mode. -Carl
Posted on Jul 07, 2009
  • 903 Answers
SOURCE: How do you change the date and time on a Ricoh 3800L fax machine?
To change the date and time on a Ricoh 3800L:
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
Posted on May 29, 2010
ZJLimited
  • 17970 Answers
SOURCE: I have a Rocoh Fax 1700L fax machine and its not
The technical manual is stating that the problem is with the left lock lever make sure that the door is shut correctly power down then back on again. If the problem comes back I think it maybe the laser unit then and it will need replacing. Also could check here the Fax 1700 Service (RAR zip format)
Keep us updated.
Posted on Feb 09, 2011
I have a Rocoh Fax 1700L fax machine and its not receiving faxes. We can send faxes but not receive them.
Keep us updated.
Feb 09, 2011 | Ricoh Office Equipment & Supplies
On digital screen of copier code sc555...what is the problem approx. how much to repair?
fuser temperature problem code.IF YOUR MACHINE IS A RICOH,SAVIN.
GESTNER, OR LANIER YOU CAN TRY TO CLEAR IT YOURSELF.PUSH
YELLOW CLEARALL BUTTON THEN ENTER 1,0,7.STOP HOLD THE STOP BUTTON DOWN UNTIL THE SCREEN CHANGES ABOUT 3 SECONDS.PUSH THE ICON BOX THAT SAYS COPIER SP A NEW SCREEN WIIL APPEAR DO NOT TOUCH IT. TURN THE MAIN POWER
SWITCH OFFFOR TEN SECONDS.THE MACHINE WILL ATTEMPT TO
RESET AND WARMUP PROPERLY IF CODE COMES BACK YOU WILL
NEED SERVICE ABOUT 200.00 FOR FIRST HOUR PLUS PARTS IF NEEDED
May 10, 2010 | Office Equipment & Supplies
How do I turn off the fax notification on a Ricoh Afico MP 3500
Most Ricoh multifunction printers have a set of parameter lists that control reports and journals. The parameters are set by using bit switches in the User Tools, and each machine has different switches to control different settings.
What kind of fax machine or printer do you have? The user manual has a list of all parameters and bit switches.
Jan 21, 2010 | Ricoh Aficio CL2000N Laser Printer
Won't always transmit the fax.
what is the error code? the solution is to find the error code and what it means in the manual.
Oct 22, 2009 | Ricoh FAX3900L Plain Paper Laser
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
No fax tone giving if this fax mode only
May 05, 2009 | Ricoh FAX1900L Plain Paper Laser
Dec 23, 2008 | Ricoh FAX3800L Plain Paper Laser
I have a ricoh fax4700L that has a error code of : [0-05H] What is it and how do I clear it?
This is a fuser error. Most probably the thermostat is open. !st try to clear the error code like so:
Press these keys : Function 61995 Yes 0 6
Then press 0 for RAM reset.
Enter address 4805AF right arrow and set the data to 00
Switch machine off and then power on. If the error code re-appears after 30 sec, then change the thermostat and service the fuser. Do the re-set thingy again.
May 08, 2008 | Office Equipment & Supplies
Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Nov 07, 2007 | Ricoh FAX3800L Plain Paper Laser
jasbo
jasbo
