Question about Chi Mei Corporation CMV-221D LCD Monitor
Chimei 22ea lcd driver - Chi Mei Corporation CMV-221D LCD Monitor
Can I purchase a replacement stand for my chimei 222H monitor? If so where?
I have broken the mounting arm of my Chimei CMV 222H ...
www.fixya.com/.../t14977283-broken_mounting_arm_chimei_cmv_222...
Nov 12, 2012 - ... the mounting arm of my Chimei CMV 222H monitor, can you getreplacement arms? The locking mechanism - Chi Mei Corporation CMV-222H 22 inch LCD Monitor question. ... Video; Photos; Link; Replacement Parts. Add.
Repair Kit, Chimei CMV 221D, LCD Monitor, Capacitors ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Dec 15, 2015 | Computers & Internet
Sound now not working on monitor
have you try to use headphone or other speaker except on the built-in speaker of your LCD?, if the sound still not working then re-install the sound driver of your motherboard.
Thanks
Sep 10, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
Need driver
Try this site i always get my drivers from this site www.driverguide.com its one of the best driverdownloads site i've known for awhile.
Jun 08, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
Can't reset the monitor settings. It's is working. Best to reload driver?
You will never reset your monitor updating your monitor driver. There is buttons on it check your manual. And of course never forget to update your videocard drivers.
Jun 07, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
Where can I download an English manual for a CHIMEI - CMV633A monitor. The ones on their site are only in Chinese. Thank You
try www.chimei.com.tw then you click on the English. it will give you the English version.hope this helps.or try www.scribd.com or www.w9drugs.org
May 07, 2011 | Chi Mei Corporation CMV-633A LCD Monitor
19"chimei Lcd. Screen stays black.
probably power supply, dac-19m015, 2200uf bad capacitor.
Apr 26, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Chimei Monitor
my monitor chimei tco3 is black and will not show sceen
Jul 30, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Monitor driver
you can set a resolution of 1440*900..
option 1) open device manager,, update the drivers for standard vga card.. locate ur video drivers folder,,(do it manually even if u have it on cd)...
option 2) this one is bit risky.... open add new hardware wizard and add ur correct video adapter, no matter ur standard display adapter is already installed. after you finish, update ur original standard display adapter and this time, it will pick the correct drivers.. now you can remove your dumb display adapter and restar pc .
risk is- be very careful, u dont want to remove your physical adapter by mistake, resulting no video after a restart.
Oct 17, 2007 | Microsoft ChiMei CMV938D 19" Widescreen...
CHIMEI CMV938D 19 WIDE SCREEN LCD volt
I have the exact same monitor and it is 220v. But seeing as i bought it in Australia that makes sense. If yours was purchased in North America then it is almost definitively 110v. It is likely that it is written on the actual monitor. If in doubt you could always try it with 110v. If that works then theres your answer. If it doesn't then its probably 220v.
Open Questions:
cmv221d wont power on even after changing capacitors Not even the LED or any response from the screen, nothing.. I ordered replacement capacitors, all except the big 400v one, replaced them all.. nothing's changed. I've ordered the big capacitor's replacement just incase, but heard they rarely break.. any other ideas of what the problem might be? The guy who gave me it said that he thought all that was wrong with it was a line across the screen (corresponding to where he said that line was, I found some dirt on the edge of the connectors). It actually did not power on as it was supposed to, according to the previous owner, who made no profit by giving it to me. A tiny part of the circuit-board did get slightly peeled when pushing one capacitor in, but only about 3mm across, affecting two small strips of whatever those little chrome strips are, but I soldered it back down.. I may have also re-attached the large Capacitor, and in folding it back down, had to force it.. could this have internally damaged it easily? This is the first time I've done anything like this, but I have followed a tutorial and learned the correct technique for soldering. Does anyone have any ideas what else it could be? The fuse looks fine. The power cable works in other monitors. I hear a little crackling if slowly pulling out the power cable as you'd expect with any screen if you listen close (atleast in Australia, I remember being surprised at how much things crackle here after moving from the UK). But yeah, basically the screen is stone cold dead, no response whatsoever..
Dec 27, 2012 | Chi Mei Corporation CMV-221D LCD Monitor
See all Chi Mei Corporation CMV-221D LCD Monitor Questions
Chi Mei Corporation CMV-221D LCD Monitor Logo
105 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
giarcnameloc
Level 1 Expert
Jax Planet
Jax Planet
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
