Question about Vocopro CDG-8000 Professional Dual CD/CDG Player CD Player
Error+ 60 cd player
Soundlab dual cd player model 2120 one side of the player displays this message error+60 had it a part and looks like the drive does not lift up to engage cd disk
CD player displays error code: ER-1
That error code means an unknown error has occurred. Try cleaning the player itself, along with the CD's prior to insertion to see if that helps.
Feb 02, 2014 | Dual XD1228 CD Receiver
The ER-1 code signifies an unknown error. Try cleaning the player itself, as well as cleaning the individual CD's prior to inserting them.
If that doesn't remedy the issue, ask for further help.
Feb 02, 2014 | Dual Electronics XD1222 Car USB Player
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
Right side cd player shows error on screen and is not recognizing a cd in there (shows error)
You have a mechanical problem with CD drive. Needs to be replaced. Let me know if you need help. digitalrepair@hotmail.com
Jan 27, 2010 | Nu Mark Numark CD-Mix-2 Dual CD...
Drive a will not open- display shows error
I repaired a couple of these before and the problem was in the loading mechanism,under the tray there is the loading motor and a drive belt that connects it to the gears ***`y, if youre a handyman you can take it out but be careful and look how you dismantle/reassemble the tray, also look for dried up grease on the gears center hub.
Nov 02, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Sep 08, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Error message E-60
First, run a chkdsk (or scandisk) to your Ipod from your computer (like any other hard disk drive on your computer)since it is probable that the Ipod's hard disk drive may contain errors. Then, follow these steps: 1.) Disconnect the Ipod from the KCA-IP500(the Ipod interface) 2.) Press and hold the middle button and the top button at the same time. 3.) The Apple Logo should appear. 4.) Reconnect your Ipod to the KCA-IP500 5.) The head unit should display loading and then respond to the IPOD interface.
Nov 08, 2006 | Kenwood KDC-MP232 CD Player
Vocopro CDG-8000 Professional Dual CD/CDG Player CD Player Logo
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
