Question about Sennheiser Digital Wireless Headphones rs160
RS 160 HEADPHONES ARE FLASHING ORANGE
THEY SEEM TO FLASH WHILE CHARGING
Not working
when I put my ps3 on it comes on and starts to flash orange and then it gose of and ,makes a sound that it cant start and starts to flash red.plz help someone!!
Dec 29, 2013 | HP Ipaq Bluetooth Stereo Headphones...
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Apr 08, 2012 | Dell Inspiron 5150 Notebook
Lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Feb 01, 2012 | Lenovo G550 Notebook
Flashing light opposite ink symbol
Indicating cartridge faulty/exhausted, replace the cartridge..
Oct 11, 2011 | HP DeskJet F380 All-In-One Printer
Canon A720 IS camera will not take a picture when flash is turned on but will if flash is turned off. I see a flashing flash symbol in the LCD panel (as if it is waiting for the flash to charge) when...
Dear sir,
It seems  ur battery is weak , since it  use  AA battery put new alkaline batteries  & then try .. I beleive it will take pictures  with snap .
Regards
Raj@npconline.in
Feb 12, 2011 | Canon PowerShot A720 IS Digital Camera
What to do when your vectron wave is blinking red and green at the same time while charging.
When you attach the charger the wrong way round it will flash red and green. Turn it around and it will just flash red. Then when charged it will go orange.
Dec 12, 2010 | Master Heaters Air Hogs Orange Vectron...
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Bmw k100 rs 1991 abs flash
Need service on abs system
Jul 02, 2009 | 1992 BMW K 1100 RS
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Sennheiser Digital Wireless Headphones rs160 Logo
65 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
