Sc672 aficio mpc7500 - Office Equipment & Supplies
I ran memory clear on Ricoh Mpc7500.Colour document appears double.Run force line position with sp2111 still no + result. unlike other mpc where you have a, b and c to execute, Any idea pls
kindly ensure there is enough toner in the machine and as well ensure that the transfer belt and unit is properly claen .
you can then run the force line adjustment.
goodluck
Jan 02, 2016 | Ricoh Aficio Office Equipment & Supplies
Paper always jams even without starting,,,,specially when im going to print cardstock, it never works
Jams from where? Need more info. Cardstock must be printed from the Bypass Tray ONLY. Make sure you select the proper paper type from the Printer Properties tab in the driver.
Oct 13, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
I have ricoh mpc6000 there is error code 300 how to solve
SC300 D Drum charge corona wire error: K
The output of the charge corona wire of the black PCU is abnormal. • CGB power pack connection loose, broken defective
• Check CGB power pack connection to BCU
• CGB power pack defective
• BCU defective
• Replace OPC drum More likely needs a new Charge assy. or Charge grid. Roughly $20-$100 for part(s).
Apr 29, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
Error code is sc672 on display ricoh mp2550n
change the bicu board and the problem will be solved
Good luck.
Apr 05, 2014 | Ricoh Aficio 1013F Copier
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
We've a Ricoh MP3500 that is displaying an error code SC672 and directs us to switch the main power and switch back on. When switched back on, we have the same error code. Advice?
sc672 is a communication error between the controller board and some other component. Did you switch the machine off using the orange power switch on the lower left side, or just the power button on the operation panel?
With the power completely off and the machine unplugged, pull the controller board out by removing the two screws holding it in on the rear left side of the machine. (It should slide right out the side.) Check all of the connections on the board and make sure everything is sitting securely, then reinstall the controller board.
Worst case scenario, you might have a bad memory stick, bad controller board, or another bad circuit board, but more than likely there is a connector somewhere that just needs to be set securely. You can also remove the operation panel (two screws on the top of the panel and possibly two screws underneath it as well) and check the harness that connects the op panel board to the machine.
Jul 16, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh 1035
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Jul 31, 2008 | Ricoh Aficio 1035 Copier
16 people viewed this question
k24674
