Question about Sharp Half Pint Microwave Oven
TIMER STOP WORKING ,MICROWAVE KEEPS RUNNING - Sharp Half Pint Microwave Oven
Timer counts down. Microwave keeps going
It is a bad door switch, or the keypad control board is the issue.
Apr 11, 2012 | KitchenAid KCMS145J Microwave Oven
Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and...
Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
Nov 28, 2010 | Kenmore Microwave Ovens
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Microwave Model JVM 1870 stopped heating, all else works (timer)
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ggk
Nov 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave keeps running after door has been opened
this is potentially a major design fault and could be dangerous. contact the manufacturer immediately.there are other post on the site saying the same
Feb 21, 2009 | Kenmore 63672 Convection/Microwave Oven
Help, my Panasonic NNA724M Combination Oven will no longer microwave. I can set the microwave going but after 20ish seconds the microwave stops and timer is replaced by the clock, without any audible...
This is an inverter model, and when they stop after 20 seconds, it usually means a problem in the high voltage section, either the inverter or the magnetron.
If you don't have experience troubleshooting high voltage inverters, I recommend calling a pro.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 01, 2008 | Microwave Ovens
Timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Sharp Half Pint Microwave Oven Logo
18 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
