Question about Miele CVA4070 Coffee Maker
F 18 error code - Miele CVA4070 Coffee Maker
I need help to clear error 18 on konical minolta 240f.
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Nov 19, 2017 | Minolta Office Equipment & Supplies
Rinnai Avenger 25 Error code 18
According to the owner/service manual I found for you, code 18 means "Temperature sensor faulty -- Service call." You can download the entire manual at the link below, the information about this code is on page 17.
Note: the manual includes information for 3-4 models. http://www.rinnai.com.au/media/748133/CI_Avenger_Blaze_Dynamo_Enduro__1_.pdf
May 26, 2014 | Heating & Cooling
Error code 18
checked the fusing unit then perform menu,*,45
Nov 19, 2013 | Muratec MFX-2830 Black and White Copier
Who to fix a demon materialized while pooting error code:18
Hey hii
Mr developers
I want to root my vivo y51l but there is some issue during the process of root error code 18 showing over there so please help me what m I do for it
Nov 08, 2013 | Computers & Internet
2008 yamaha r6 error code 18
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/46-general-discussions/57813-r6-2k7-error-code-18-a.html
How To Yamaha R6 homemade exup servo plug Code 17 18
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jun 09, 2012 | 2008 Yamaha YZF-R6
2007 yamaha r6 fault code
I have 18 error code problem in my bike what can i do?
Apr 01, 2010 | 2007 Yamaha YZF-R6
Engine diagnostic pulled codes 48 and 18
Hope fully you've already solved this problem. If not the problem just sounds like it a comms error between the diagnostic equiptment and the car.
Mar 16, 2009 | 2001 Volvo S40
Error #18 Lens will not close and camera shuts off
Hey louboyens,
According to the manufacturer error code 18 is a lens error code. What that means is something is obstructing the movement of the lens. I would make sure that your hands or anything else is not preventing the lens from moving correctly when your powering the camera on, and make sure the camera is powered off and not powering on while in your camera bag. Try turning it off and back on and after this the camera still displays the error code you should probably have it looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 15, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Miele CVA4070 Coffee Maker Logo
13 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
