Question about Aurora Electronics Office Equipment & Supplies
Want to reset +Tax function - Aurora Electronics Office Equipment & Supplies
Tax function not working
After programming the tax you also have to link the taxable PLUs or department to tax by using the digit one and 0 for the non taxable
Jan 28, 2014 | Sharp ER-A320 Cash Register
Tax Function on Canon LS-121TS
The LS-100TS has tax keys. I suspect (for I cannot have access to a manual, just the online brochure by Canon) that you have to switch left to right or up-down one of the tax keys then you enter the tax percentage. and toggle back into position.
Oct 11, 2013 | Canon LS-100TS Calculator
My calculator is set at a 5% tax rate. How do I reset it to a 6% tax rate?
Observe the devices function keys to ascertain any menu or mulltifunction buttons. Multifunction keys perform several features. First the multi key integrates several features to minimise the extraneous requirements wit micro computer keypads. Second, multifucntion keys perform the additional fucntions least visible at initial observation. Calculors as simple computers onlyl produce transaction requests though allowing to adjust features to suit productivity. Perform an observe of the device to familiarise with the adjustment status condition. In the instance were the device were dessign least to allow an alteration of calcultion percentages makes alteration unachievable. Refer to the devices oner user guide to ascertain the capacities if functionalities among several resources made available from the manufacturer.
Feb 13, 2011 | Casio DR-210HD Calculator
Tax-
The Tax- function allows you to take the total cost (sub-total + tax) and it will subtract the tax and leave you with the sub-total (before tax).
Example:
If the item you have is $5 and the tax is set to 5%... when you use the Tax+ key it'll give you 5.25.
Conversely, when you enter 5.25 and press the Tax- key and it will give you the base price of $5.
So the Tax- key removes the tax from the total amount.
It doesn't remove the percentage OF the total amount.
Aug 06, 2009 | Casio MS-80TV Scientific Calculator
Setup for tax function
Probably needs a developer change. Requires a technician.
Apr 27, 2009 | Office Equipment & Supplies
Tax function settings
Press C/AC. Press and hold down SET/% until "SET" appears in the display. Press TAX+/TAX RATE. Enter your new tax rate. Press SET/%. Done!!
Mar 21, 2009 | Office Equipment & Supplies
Setting the VAT calculation function
Press and hold SET button untill set appeares.
Presa TAX RATE batton, enter requred tax. Press set button.
Job done!
Dec 22, 2008 | Office Equipment & Supplies
NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Jun 05, 2008 | Sharp EL-2192Rll Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Jun 11, 2007 | Casio MS-80TV Scientific Calculator
27 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
