Question about Casio Parts Cash Register PC Desktop
How to name a dept key - Casio Parts Cash Register PC Desktop
  • Casio Master
  • 1,711 Answers
Type in the programming sequence for department text (sometimes called department name). When you get to the part where you enter text, use the table for entering characters from the book. It will show you how to convert the codes into text. If you have lost your manual, one of the users has most of them here:
http://the-checkout-tech.com/cashregisters.php
Posted on Apr 24, 2014
How can I wright dept name in till?
pop the top of key off and write on paper and replace
Apr 12, 2015 | Retail Supplies
How to name a dept key on te2200
There is a table which shows you the codes to type for each character in the programming book. If you need the manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Mar 18, 2014 | Casio Parts Cash Register PC Desktop
WE HAVE A SHARP ER-A610 CASH REGISTER WE WOULD LIKE TO CHANGE THE ITEM LABEL FOR EACH DEPARTMENT KEY BUT DON'T KNOW THE JOB # AND PROCEEDURE FOR DOING IT I DON'T HAVE ALL THE PAGES OF THE MANU
Sharp uses a 3-digit ASCII code for each character. The ER-A610 manual has a table of the codes, but if you've lost that part of the book, you can find ascii tables online, like this one:
http://www.ascii.cl/
Note that many of these show 2-digit codes; add a leading zero to those, so A is 065, B is 066, etc.
the 00 key on your ER-A610 has a special purpose here - it is used to enter each character's code, so to spell FOOD you'd enter:
070 00
079 00
079 00
068 00
where each of those double-zeroes is the double-zero key, not just two zeroes.
You need to know the number of each department you need to change. If you're not sure what order they're numbered in (It's completely customizable, so don't count on them being in order, unless you're sure.), print out your current department programming:
(In PGM1 or PGM2 mode)
1100 @/FOR CA/AT
will print out all the depts. CA/AT is the Cash key at the bottom-right corner of the keyboard. It stands for CAsh / Amount Tendered, which isn't exactly obvious, so some folks relabel it.
Note that on the tape you printed, the name is printed below the dept. number.
Now we're ready to start. In PGM2 mode, enter:
2114 . @/FOR (Is the decimal point after the 2114 visible here?)
[dept. number] @/FOR [character codes] SBTL
(etc. until done)
CA/AT
For [dept. number], enter the number on the keypad, not by touching the actual dept. key.
[character codes] is the sequence of 3-digit codes and 00 key presses, like the FOOD example above.
If the departments you're changing are sequential, life is a little easier. When you finish Department 6 (for example) by touching the SBTL key, it will automatically count up to 7. You can do a series of depts. by entering the first of them as above, then after using the SBTL key, go straight into the character codes for the next in line. Continue this way for as many are in series. You can jump ahead or back at any time by with [dept. no.] @/FOR and keep going from there.
SBTL in all the lines above, means the key that normally shows your subtotal including tax. It might be labeled #/SBTL. The MDSE SBTL key won't do the trick.
If you use PLU's in you register, their names are programed exactly the same, except that instead of starting with 2114, you use 2214. Simple, no?
Jan 11, 2013 | Computers & Internet
Enter DEPT.ID & DEPT.ID Password how can i solve it can any give to reset setting codes
You will have to reset/clear the password. This WILL REMOVE all passwords setup in Dept ID Management. Go into Service mode by pressing the Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, PWD-CLR, Then Ok. You may also use the arrow keys on the display to get to PWD-CLR. Then the RESET key or maybe power down the equipment.
Jun 17, 2011 | Canon Office Equipment & Supplies
I'm working with a PCR T2100 and trying to re-program the unit price for each department. I have the manual so I've read the key set to pgm, press 1, subtotal, * (dept #/dept shift for upper departments),...
Turn the key to PGM mode. Type the new price without decimal point e.g 500 Press the dept key (item) you want to change. Press SUBTOTAL Turn key back to REG and test it.
If anyone needs a Casio PCR-T2100 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Nov 19, 2010 | Casio Parts Cash Register PC Desktop
Hi Mark. You instructed me to set the department names but i haven't got a clue if where is department key like the ones for Flat PLU button key. Please help! Thanks. Clarence
Sorry, I didn't know you hadn't worked with departments yet.
Key to program 2 SUBTOTAL Now type the dept number on the numeric keys (i.e just press 1 for dept 1) 05 SUBTOTAL Now type the new name for that dept 00 (double zero button) CASH SUBTOTAL
Sep 27, 2010 | Casio Parts Cash Register PC Desktop
Hi Mark, I start setting items with amounts to flat Plu001 – 006 and for test purposes I link to Department 1 – 6 as well e.g. flat PLU001 link to Dept 1, flat PLU002 link to Dept 2 upto flat PLU006 link...
In that case, you want to check that you have linked them correctly.
Turn key to program. 6 SUBTOTAL 304 SUBTOTAL 1 CASH 6 CASH CASH
This should print the status details for the first 6 PLUs. Check to see that the department link is the way you programmed it.
Sep 22, 2010 | Casio Parts Cash Register PC Desktop
Trying to identify name of a part/car won't start
it is called the lock cylinder housing..it may be available..i will check tomorrow at work..parts dept should be able to find
Oct 29, 2009 | 2004 Dodge Neon
CE-7000 Program Departmental Names and program post receipt print
Hi.
3 SUBTOTAL
100000000000
RECEIPT
SUBTOTAL
That should allow you a post receipt.
To set dept names:
2 SUBTOTAL
Department number
05
SUBTOTAL
Type new name
CASH
SUBTOTAL
If it gives an error when pressing CASH, then repeat, but press 00 button before CASH (some models need this).
Jan 23, 2009 | Casio Parts Cash Register PC Desktop
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
44 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
