Question about Canon imageRUNNER C6800 Copier
E000070-0201 It's warming up , then the error appears
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
CHECK OR CLEAN YOUR ITB BELT
Posted on Nov 09, 2014
I replaced the control board and display, but it appears the touch pad is the problem. Can I buy it separately?
Hello. The part number you need for the control panel/switch assembly is 74011491. The actual oven control unit is 74011494. The following list shows some(but not all) of the error codes you might encounter. I hope this helps you!
1c1c shorted key
1c2c membrane keyboard disconnected
1c4c board to board communication failure...." "
1c6c EEprom hardware fault..........................." "
1c7c control not calibrated............................... replace main board
1c8c eeprom crc error--user options..............." "
1c81 eeprom crc error--cook profile................." "
4d21 no cooling fan rotation
4d31 cooling fan on when de-energized
4d41 cooling fan overspeed
4d51 door switch circuit fault
In the service manual, there was no "warming drawer" error code listed in the code chart.
Aug 29, 2015 | Jenn-Air JES9750BAS Stainless Steel...
How to solve the wrong cartridge sign appear?
Wrong cartridge is a printhead error!Replace it and it will be okay!
Feb 11, 2010 | Canon Office Equipment & Supplies
Printer displays fail to warm up whenever it is turned on
Fuser is not coming to ready...sorry, but "yes", you did lose $100
Jul 17, 2009 | Brother MFC-7820N Printer
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Mar 11, 2009 | Ricoh Office Equipment & Supplies
Service required? 37,002,47:198356 error can anyone assist?
37,002.47 The Left Jetstack is drawing less power than expected.
arrwup.gifInitial Action
  • Check the Printhead, Preheater and Ink Loader power connections.
  • If the problem persists, follow the procedure below.
arrwup.gifPrimary Causes The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure
Apr 08, 2008 | Xerox Phaser 8550DX Laser Printer
ERROR CODE
thanks for posting the solution. it may help other users
Robert
Nov 28, 2007 | Minolta DiALTA DI2510F All-In-One Laser...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | OKI C5150n Led Printer
Canon imageRUNNER C6800 Copier Logo
71 people viewed this question
old marine
old marine
