Question about John Deere Garden
Misfire on lx289
Engine runs uneven at full throttle
3 Suggested Answers
  • 67 Answers
SOURCE: Misfiring
If you are getting a lot of misfires and you know everything is good (i.e. spark plugs & wires, etc...), you may want to check the cat converters as one may be plugged. you can use the front O2 ports to check this.
Posted on Jun 06, 2009
afarri
  • 1386 Answers
SOURCE: Triumph America 2006 9000k. Cold
Hello and welcome to FixYa!
Have you tried replacing the spark plug wires and checking the spark plugs? I suspect that you have fuel flooding that's why it backfires. Good current to the spark plugs will result to better fuel burning. Check the spark plugs if they have big gaps, covered with carbon or maybe it's just faulty.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jun 14, 2011
Starts up but runs rough, exhaust smells, and when you give it gas it wants to shut off.
How To Fix P0300 random misfire codes in your car ...
? 2:56
https://www.youtube.com/watch?v=OyvdWeyDHf4
Feb 5, 2010 - Uploaded by Scotty Kilmer
Scotty Kilmer, mechanic for the last 46 years and counting, shows how to fix your car if the check engine light ...
P0300 - OBD-II Trouble Code - RepairPal
repairpal.com > Encyclopedia > OBD II Codes
OBD II Fault Code. OBD II P0300. Fault Code Definition. Random, Multiple MisfireDetected. Symptoms. Check Engine Light flashing; Rough running, hesitation ...
P0300 - Check Engine Light Diagnostic Trouble Code ...
https://www.engine-light-help.com/P0300-check-engine-light.html
The misfire detection monitor, a software strategy built into the computer, is designed to detect an engine misfire. The computer can also normally identify the ...
Random-Misfire Page
www.random-misfire.com/
Jan 24, 2016 | Cars & Trucks
I have a1995 GEO prism it runs good but when I let off of the throttle it won't idle unless I keep my foot on the throttle
Clean the throttle body and idle air control motor. Just a cheap start. Could be the engine is old and tired.
Sep 07, 2015 | Geo Cars & Trucks
06 suzuki xl7 sputters and almost dies while idling but seems to run fine when it is given gas
try a full tune up yet.
you know, the LISTED spark parts and all filters.
this decade.
ever to the Full 60k list?
what engine, no engine stated, there are many.
we can fix misfiring car bodies, only engines.
misfire, can cause by over 50 things.
even a bad spark plug. if gas engine.
Jun 30, 2014 | 2006 Suzuki XL-7
Uneven idle while running and in park but no check engine light
The idle air control motor is dirty. It's mounted on the throttle body. Clean the plunger and spring with brake clean, you clean use a soft wire brush or tooth brush. Also clean the hole it came out of. Wouldn't hurt to use the brush and clean as far as you can in the throttle body. It will take a second or two to start after you do this, Then run normal afterwards.
May 02, 2014 | 2006 Chevrolet Silverado 1500 2WD
JD Lx289 Surging at full revs, and full accelleration. Grinding noise and accellerator pedel vibrating/pulsating. more common when machine is warm.
When it is at full throttle start pulling the choke on slowly and see if it smoothes out and stops surging.if it doe,s you have a carb problem.this means it is getting too much air.you will have too rebuild or replace carb.
Dec 09, 2010 | John Deere 22HP Hydrostatic 42" Riding...
I dont know if it is a problem, but on a 2009 TT_R125EY Yamaha, the engine runs uneven at slow speeds, almost like misfiring, and seems fine at higher engine RPM. The bike is new with maybe 10 hours on it,...
Uneven running can be the carb settings, possible too lean( is it better or worst with the choke on?)
If its new, let your dealer know, it is a warranty problem.
Jun 02, 2010 | 2003 Yamaha YZ 125
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
Misfiring
May 18, 2009 | 1999 Mercedes-Benz E-Class
Garden Logo
11 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
