Question about Zojirushi EC-BD15 10-Cup Coffee Maker
Zojirushi phone number
Ran hot water thru machine now the clock is the only thing that works
2 Suggested Answers
SOURCE: Zojirushi electric dispensing pot
Got greasy white stuff floating inside the kettle, any idea where this comes from? And how to eliminate it besides getting a new one. This unit is over 5 years old. Thanks.
Posted on Nov 12, 2008
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
My Zojirushi BBCC-S15 works even though the window blinks 8:00. Why is a battery needed?
Some automatic breadmakers have a place for inserting batteries.
The intent is to create a memory back-up for two things:
1: The digitally-displayed clock setting, and
2: Personalized program settings you save to the machine to perform again later.
Now you're not required to install or replace the batteries in your breadmaker unless you desire these settings to be maintained long after the breadmaker is unplugged.
And, if you do decide to install or replace the batteries be certain to use alkaline-grade or better.
But be forewarned though: Breadmaker clocks don't adjust for DST (Daylight Saving Time)
Hope this helps!
Jun 24, 2011 | Zojirushi BBCC-V20 Home Bakery Traditional...
The washer fills only with cold water. if warm or hot is choosen, you hear a noise (sounds like something is straining) but no water comes thru. but the washer continues as if water has come thru.
try taking off the hot water hose(from the wall) and make sure the hose has no obstructions. My did the same thing,after I cleaned it out it worked fine.
Aug 17, 2010 | LG WM1812C Front Load Washer
How do I clean the Hot Water Dispenser?
I have zojirushi 4L (model: CD-LCC). I noticed that the bottom of the pot have some stain which are looked like "corrosion". What should I do? How to remove it? Please help.
Thank you
Nov 01, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
Oct 18, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
XP 2070 Won't Stop Beeping
Okay, I had the same problem, started beeping and lights flashing one day, unplugged it and it was okay for a few days then this started happening more often until the machine just beeped and blinked all the time and would not make espresso. When I called Krups customer service I was told it sound like a circuit board problem and to send it in, yes its under warranty but I have to pay shipping both ways, so I decided to check it out myself. So here is the bottom line and what worked for me, I removed the espresso screen (above coffee grounds holder, 1 phillips screw) and ran 4 tank fulls of descaler thru the machine. the hard part was getting it to pump thru the machine. I found if I ran water thru the hot water/steam nozzle first I could get it to run 1 or 2 cycles, I also found that by removing the water tank and turning the system on for a few seconds and running pump dry (not recommended) I could get it to cycle without blinking for a few turns. Ran the 4 tanks of descaler thru, then ran 4-5 tanks of water thru into a bowl until it ran thru clean. The machine is 4 months old and I was shocked at the amount of crud that came out. It now runs fine and no more blinking, If indeed this is the fix for this you would think someone at Krups would have a clue, but I guess there a useless a the owners manual for the xp2070.
Thanks and I hope this helps.
John
Apr 24, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Dec 18, 2007 | Saeco Royal Professional Espresso Machine
Zojirushi EC-BD15 10-Cup Coffee Maker Logo
48 people viewed this question
Top Zojirushi Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Zojirushi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
