Question about LG DLE2532W Electric Dryer
Dryer Door Clouds over with Condensation. I found
LG Dryer Door Clouds over with Condensation. I found about 3/8 of a cup of water in the dryer drum last night. Dryer Screen is damp, but clean. Kathy
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Do you have the model DLE2532W which you posted under, or is it some other model? Please post the model number from the sticker on the frame behind the door.
  • 525 Answers
Your dryer is not venting to the out-of-doors. Try removing the vent tube from the rear of the dryer and checking it all the way to the outside for an obstruction,i.e. lint build up, water retention, animal nest, etc. Make sure there are no sags if it is a flexible vent tube, no pinch off points, short as possible... most dryers can only have a 10-15 ft. length of straight tubing. A mechanical failure of the blower could also cause the issue.
Illeagle
Posted on Jun 29, 2009
Why is my Maytag Bravo steam dryer leaving my clothes damp
If there is water in the hose, water is getting in through the vent on the outside. Try cleaning where the flap on the vent rests of lint and build up. Also check that the vent is fastened in the ground. If it's loose, water will seep in around the seal and get down into the hose.
May 12, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I currently live in the midwest and today has been an extremely humid day (90 degrees+ and 84%+ humidity). I used our LG gas dryer (Model # DLG2241W) earlier this weekend and it worked fine. Tonight, when...
Water in the drum anytime after drying a load of clothes is not normal.
Was the load prior to you having found the condensation fully dried? If not, check for lint in the vent system and make sure that air is coming out of the vent (the flap or louvers on the vent cap should open fully on a short vent line). Even so, this would not account for a small amount of standing water in the drum.
The first thing that came to mind was outside air being drawn in through the vent. If you have air conditioning and a well-sealed house, the warm, moist air hitting the cool drum (in a relatively dry atmosphere) may cause condensation. Check the outside vent to ensure that the vent cap flap (or louvers) is (are) closing all the way. Convection or air flow from the basement to a vent fan in an upper level might cause this.
Please let me know if I can help further.
Jul 18, 2011 | LG Dryers
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
My dryer has a build up of water and give an F03 error. What can do to fix it?
Aug 08, 2010 | Bosch WTE86300 Electric Dryer
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
Dec 12, 2009 | LG DLE3777 Electric Dryer
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
Does not dry thoroughly in sensor mode heard that softner sheets may require cleaning the sensor . How do you find and clean sensor.
First, I always set the dryness level at the maximum dry level, because the Korean's "Normal Dry" is what we call "Damp Dry". The sensor is located just inside the door, by the lint filter. If you stick your head into the dryer drum and look back toward the filter you will see it. (two curved metal bars, about an inch apart and about 5 inches long.) Clean with soap and water, or I've heard rubbing alcohol works. If your sensor bars need cleaning, the dryer usually will go quickly to the 6 minute mark after starting.
Oct 16, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Hello, getting an error of F:03 on my WTE86300US Bosch Condensation Dryer. Do you know what the issue is?
Aug 06, 2008 | Dryers
Gas dryer
AJ...the only thing that is going to cause this is a blocked vent or pinched vent hose. You need to make sure that all the venting is clear to the outside.
Jan 13, 2007 | LG DLG5932W Gas Dryer
LG DLE2532W Electric Dryer Logo
293 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
