Question about Dell E173FP 17" LCD Monitor
When plugged in the monitor and the power button flashes every 2 seconds?
    Scholar:
  • 47 Answers
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's most likely the problem. You can confirm that it's actually the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Posted on Jun 18, 2009
Power Switch comes on but moniter goes back to sleep.
use external monitor to setup internal monitor setings
Nov 10, 2012 | eMachines T3508 PC Desktop
Monitor will not stay powered up
It is possible that the monitor is going back into "Sleep mode" meaning it is not detecting a valid signal from whatever device it is plugged into. I would try replacing the cable that is connecting the monitor to the PC or Console. As a trouble shooting step try pulling up the "Menu" on the monitor itself by pressing the "Menu" button on the front panel of the monitor, if this does come up then we can say that the LCD itself is most likely working.
Nov 10, 2012 | HP Compaq WF1907 19 LCD Monitor
Acer monitor will not start, power button flashes
hi Samuel.
this is all i could find from the internet.
You can try a power reset to see if that helps. To do a power reset, unplug the power cable and press and hold the power key for 10 seconds. Then, release the power key and plug the monitor in and attempt to use it. If you are still unable to get a proper display, We would suggest contacting technical support to inquire about warranty repair options. Many of our monitors carry a 3 year warranty, so there is a chance you may still have warranty left.
Acer Service and Support
you could also try this link out.
Acer 22 X223w LCD Monitor will not start up Google Search
Dec 14, 2017 | Acer 22" X223w LCD Monitor
HP L2208W monitor. Unplugged it, working perfectly, moved it (carefully) to another desk, now it only says "no input signal", but stranger is the fact that it comes on as soon as it is plugged...
nosignal means the PC its plugged into , is not sending
the 2 sync, signals, horiz./vertical.
so make sure the PC works,first, then the cable them the monitor.
this monitor is old as 2007. 1 decade old.
is the cable plugged in to the same jacks as it was.
the PC caN in fact have many jacks, DVI or VGA. even 3:
the monitor can have 2 jacks use the primary. yours has 2.
one DVI and 1 VGA.
self power on feature...hummm, the opposite of any energy saver scheme...
is the bottom right monitor button power damaged? look carefully.
to reset the monitor, unplug monitor from wall power AC
then hold the power button for 10 seconds.
release.
does it work now?
the odd self power on the power lamp shows? page23 your manual.
Green = Fully powered.
Amber = Sleep mode.
Flashing Amber = Sleep Timer mode.
ok page 26 in your manual shows there is an auto power on feature, I just read it for you. in your OSD menu.
"Power On Recall
Restores power to the monitor following an
unexpected removal of power. Select:
On
Off <**************************
The factory default is On."
NOT FRIED, at all I bet.
1: wrong cables used or plugged in wrong
2: PC died. in the move, sure can, test PC with another monitor
if fails PC is failed, if not , not.
3: wrong jacks used.
4: cable died.
Oct 26, 2017 | HP L2208W Monitor
OSD locked how do I unlock
OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Sep 11, 2009 | AOC 917Sw 19" LCD Monitor
Screen flashes on for around 1-2 seconds before turning off
Your TV has a defective component on the power supply section. Need service by electronics technician.
Jul 27, 2009 | Computers & Internet
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Intermittent Power
that means the power button is bad or some wire on the button is loose
Aug 31, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
243 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
