Question about Facebook Apps
How do I stop National Geographic from being on my Facebook
  • 3 Answers
SOURCE: Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Posted on Feb 13, 2009
SOURCE: I need instructions for the National Geographic Rock Tumbler.
Complete instruction manual to be found following the following link: http://www.sbdirect.biz/_download_files/NG09.pdf (my son also lost the instructions and I had to search the web to find another copy...
Posted on May 24, 2009
SOURCE: Free Download
i need to put code in so i can down load on my micro sd how do i do this please and thankyou
Posted on Nov 04, 2009
SOURCE: How to set time on my National Geographic Dakota Atomic Watch?
For the national geographic radio controled watch.
The easiest way to rest this watch is to remove the battery.
Once replaced the watch will flash set to 12. Push and hold the upper button till the hands spin. Press this button again to stop the hands. Tapping the upper button will make the hands move forword 1 sec. Set all the hands to 12. becareful, if you pass 12 you will have to go around again. to start the hands spinning again press and hold the upper button untill the hands move. Once all the hands are at 12, press the lower button and the screen should flas LON for london. Set the city code using the upper button to your area. press the lower button hard to confirm the information. The watch should set itself to the correct time. If it starts running from 12, place it on the window sill for the night so that it can get a signal.
Posted on Nov 06, 2009
SOURCE: dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
I have a National Geographic weather station mode ce1177 to set up.How do I do that?
Google (National Geographic)(ce1177)(manual) without parens for instructions.
Apr 11, 2018 | National Geographic Optics
How do I assemble a national geographic 76/700 EQ newtonian reflector telescope.
Try Googling (National Geographic)(76/700 EQ)(manual) without parens OR contact National Geographic directly with your request.
Jan 30, 2018 | National Geographic Optics
Software for National Geographic 265NC
I tried the software that came with the National Geographic weather station 265NC but found it not what I wanted for history data. I downloaded Cumulus software from Sandaysoft.com I have used it since 2009 and have had no problems. When setting up the station on the software use Fine Offset as a menu selector for type of station as that worked for me.
Feb 07, 2014 | NG Weather NATIONAL GEOGRAPHIC 265NC
What area is code 02080 for
02080
London
Section: Codes in Range 1000-2999 - Geographic Numbers
A table of the code allocations for numbers starting 02080 is available
Nearby area codes listed by increasing distance:
*. 01812 Geographic - unassigned (formerly London Outer Area)located nearby
*. 01710 Geographic - unassigned (formerly London Inner Area, National Dialling)located nearby
*. 01712 Geographic - unassigned (formerly London Inner Area)located nearby
*. 0200 London National Diallinglocated nearby
*. 01810 Geographic - unassigned (formerly London Outer Area, National Dialling)located nearby
*. 0207 Londonlocated nearby
*. 01689 Orpingtonabout 9 miles to the S
*. 01708 Romfordabout 11 miles to the E
*. 01322 Dartfordabout 12 miles to the ESE
*. 01959 Westerhamabout 15 miles to the SSE
*. 01707 Potters Barabout 15 miles to the NW
*. 01992 Lea Valleyabout 16 miles to the N
*. 01375 Grays Thurrockabout 17 miles to the E
*. 01883 Caterhamabout 17 miles to the SSW
*. 01474 Gravesendabout 18 miles to the ESE
Dec 28, 2011 | Area/Code Drop7
How do i use the peice that hooks up to your laptop?
This is NOT a computer controlled scope--
http://www99.shopping.com/xPO-National-Geographic-National-Geographic-70mm-Compact-AZ-Refractor-w-table-top-tripod-
You probably have some kind of CD disk that has a planetarium program on it.
Here is a review of the telescope.
http://www99.epinions.com/reviews/pr-National_Geographic_NG70CA_Telescope
Aug 29, 2010 | National Geographic NG70CA (225 x 70mm)...
National geographic telescope NG 114mm 900 EQ Who makes this telescope and would you price this at $150.00 ( used)
Manufacturer is unknown for this scope, but it probably originates in China and is resold with the National Geographic brand name, 150$ seems a little high for a used one. I would probably price it at 100-125$ depending on the condition and the included accessories, if any.
Jul 26, 2010 | National Geographic NG114EQ Telescope
Assy of ng70fs telescope
Here are the manuals for your telescope brand--
http://www.citiwellint.com/manuals.htm
Apr 10, 2009 | National Geographic Optics
Mar 16, 2009 | Toys
National Geographic
email them here:
cdromcustomersupport@nationalgeographic.com askngs@nationalgeographic.com
Dec 11, 2007 | Video Game Consoles & Games
Facebook Apps Logo
67 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Facebook App Expert? Answer questions, earn points and help others
