Question about HP Pavilion F1523 15" LCD Monitor
Input Signal Out Of Range
About last week my hp computer after i have switched it on i was expecting it to boot to my desktop interface but rather input signal out of range was what appeared  on my screen so i tried my system unit with another monitor and it was working after that i also tried my monitor with a different system unit and it also worked so after that i was a bit confused and i brought back my system unit and my computer together and connected them and it still gave me input signal out of range so i realized my hp keyboard was cordless and even thought it is not working but after i went to the system bois and had made some changes i became certain that it was working so i would be very glad if u can assist me solve this problem as soon as possible
Thanks
  • 2 more comments
  • stiga Oct 30, 2007
    it doesn't really give me the options to boot either by safe mode or last known good config or even in command prompt or if these is any other way i can go to safe mode pls teach me am grateful
    thanks and hope to hear from you soon
  • nimaa Jan 07, 2008
    well, im trying to change the resolution of my screen into something smaller, since everything is so huge and gives me headaches, but it seems like i cant change it. and always says Input signal out of range/
  • Anonymous Apr 15, 2009
    Me too. I have a 15" NEC Multisync 1550 lcd monitor that worked fine until I re-install windows (Windows Me). Now all I get is "Input Signal Out of Range" message. What might have changed?
  • Anonymous Mar 27, 2014
    i used the command alt gr + f11, and the screen turns black, with a dialog "input signal out of range change settings to 1366x768-60Hz" i tried to introduce the command control+alt+supr, it didn't make difference, so i really need how to change the resolucion
  • 749 Answers
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Posted on Oct 30, 2007
  • Rommel Balcita Oct 30, 2007
    Sorry cannot chat right now... I don't have any cam or mic right now...
Me too has got the same problem
plz help us
Posted on Dec 24, 2007
All you have to do I think is adjust the monitor video card refresh rate from 85 to like 75 and it should work for you.
Posted on Jun 03, 2008
plz help us
  • Bill Heronemus Aug 09, 2013
    I am currently working on an I-INC iF251 H monitor that is capable of displaying up to 1920 x 1080 resolution and yet, even with a 1024x768 signal, it shows "Input Signal out of Range" in a small box in the center (which is on top of the normal computer display that it is also showing) I get the same "Out of range" when I'm using the HDMI input also. So it is obviously a monitor problem in this case.
    Champion:
  • 245 Answers
Input out of range means only that refresh rate must be changed ... if u don't get windows menu or boot in windows and change refresh rate , please turn computer off (and power cord) then switch jumper CLcmos or remove bios battery and then connect it back in place. Then as windows starts POST hit delete for bios , if bios have load optimal defaults please load , and then save an exit. and your gpu's settings are restarted. This applies for PCI based graphic cards and NOT integrated ones !
Posted on Jan 22, 2013
  • Anton Trdi? Jan 22, 2013
    input out of range means only that refresh rate must be changed ... if u don't get windows menu or boot in windows and change refresh rate , please turn computer off (and power cord) then switch jumper CLcmos or remove bios battery and then connect it back in place. Then as windows starts POST hit delete for bios , if bios have load optimal defaults please load , and then save an exit. and your gpu's settings are restarted. This applies for PCI based graphic cards and NOT integrated ones !
    then as windows starts... wrong then as boot starts
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
Using a HP L1506 Monitor on a HP Pavilions a 867c computer and has worked, but now receiving "VGA input: no input signal" with window on monitor, followed by "Monitor going to Sleep" and it does. Worked...
First of all, boot your system without the monitor connected to it and when you feel that it's booted upto logon screen (or if you haven't assign password it'll directly logon to the desktop, power on the speaker to make sure you can know it's done) connect the monitor. If this isn't successful, please turn off the system and remove the cmos battery, leave it outside for few minutes and again reinstall it. Boot again normally. Still having the same problem? then let's try another method. Did you see the bios loading (black screen with white text during startup) when you power on the system? If so, press F8 several times while it is booting and select "Safe Mode" and restore your system to previous state. Do let me know if this isn't possible. Good luck Thanks for using FixYa.
Jun 10, 2010 | HP Pavilion F1703 17" LCD Monitor
What is the parts of a monitor
Part Number:RK284AA#ABA
* Display Type LCD display / TFT active matrix
* Built-in Devices Microphone , Speakers
* Width 20.6 in
* Depth 11.4 in
* Height 18.9 in
* Weight 19.8 lbs
* Enclosure Color ( The image of the product displayed may be of a different color )
* Localization English / United States
* Display (projector) image aspect ratio 16:10
* Image Contrast Ratio 1000:1
* Diagonal Size 20 in - Widescreen
* Dot Pitch / Pixel Pitch 0.282 mm
* Max Resolution 1680 x 1050 / 60 Hz
* Max Sync Rate (V x H) 76 Hz x 82 KHz
* On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit
* Controls / Adjustments Tilt
* Tilt Angle 30
* Signal Input VGA
* Digital Video Standard Digital Visual Interface (DVI)
* Type Microphone|Speakers
* Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
* Connections - DVI-Digitaligital , - VGA
* Microsoft Certifications Compatible with Windows 7
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 65 Watt
* Power Consumption Stand by / Sleep 2 Watt
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 20 - 80%
* Service & Support Limited warranty
* EPA Energy Star Compliant Yes
* EPEAT Compliant EPEAT Silver
Feb 15, 2010 | HP W2007 Desktop Monitor
MS Vista patches broke my Desktop on my HP PC
after switching on the computer press F8 & Choose safe mode to boot the system & Restore the system in previose state & Before doing this make sure u backup the C Drive.
Don't Forget to Vote
Max
Jun 29, 2009 | Computers & Internet
MS Vista Windows patches broke my desktop
reboot the computer and then press f10 this should get you a screen with a text line that says safe mode,with net or command scroll down to last settings that worked and try that ps. you really need to make a recovery disk. its that important.
Jun 29, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
You could try going into safe mode and make sure the correct drivers are installed and if they are then you can then set the correct resolution.
Feb 28, 2009 | Dell OptiPlex GX260 PC Desktop
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
When i start my computer it doesn't open windows, well it basically does all the booting up and up until it has to say "welcome" it then presents a black screen with the message: input signal out of range....
The video driver isn't set up correctly for the computer. You need to boot into safe mode - after powering on the computer, press the F8 key. You will be shown a menu. Choose Safe Mode with networking. The computer will boot using a very basic video driver. Right click on the screen and select properties. Click on the advance tab. Click on Driver => Advanced => Update driver. Once the driver has been updated. Go back to the drivers tab and click on mode. Select one of the modes. Close everything and restart your conmputer normally.
Oct 25, 2007 | Dell OptiPlex GX260 PC Desktop
HP Pavilion F1523 15" LCD Monitor Logo
10,729 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
