Dx895 initial reset
My tpv dx895 requires setup could you help me
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Turn the power off and on again
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Jan 18, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
How to master reset
Master Reset or Factory Reset
When Factory Reset is performed, the setup value will factory default setting
When initialization starts.
1.Select System Setup from Menu Screen.
2.From the System setup submenu, Set Factory Reset to ON
3.When you exit Menu, The phrase FACTORY RESET Appears on the monitor and
The Initialization starts.{ON/OFF} Use arrows UP-- DOWN & , kEY TO MAKE CHANGES
HOPE THIS HELPS
Oct 18, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
My camera sony DSC-W35 turn tha power off and on again
This may be an issue with the Lens unit in the Camera, as it is
stuck. This can be resolved by trying the troubleshooting steps
like Power resetting and Factory resetting.
Power resetting:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15
seconds.
Then, reinsert the batteries after 1 minute.
Factory resetting:(This can be performed only if the Menu is
accessible)
To reset the Camera, select the INITIALIZE Option from the
SET UP1 Menu of the Camera to OK.
If the issue is not resolved after trying the above troubleshooting steps, service may be required.
Aug 06, 2010 | Sony Cameras
LANGUAGE ON MY X6650 IS SET TO CHINESE. NEED TO CHANGE TO ENGLISH PLEASE
To do this, the machine will need to be reset, allowing you to choose the language and country on the initial setup menu. You will lose the current date, time and fax data:
1) With the power on, hold down the power button for approx. four seconds - the machine will power off
2) Press and HOLD the <Back> and <Start> buttons and press the power button - keep holding these two buttons for approx. twenty seconds, then release
3) The "Initial Setup" menu will appear - use the arrow keys to select the desired language
4) Press <OK>
5) The "Country Select" menu will appear - select your country from the list
6) Press <OK>
You may now reset the date, time and input your faxing information as required.
I hope this helps!
Jan 20, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Won't zoom :(
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Please press the Menu button on the Camera.
2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
3. Then, select the Initialize option to OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Aug 11, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Belkin f5d7633-4 f/w 1.00.24 cannot setup security,when i trying to open security,to setup wirelles key,opens empty window...any ideas
hi,
If you use any of the following then You Most probably the issue with then,,
IE with popup blocker
Personal firewalls like norton
Please dsabling them for a while and try to open.
With Regards,
TPV
Jan 30, 2008 | Belkin (F5D7633UK4A) Wireless Router
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
