Question about Casio Exilim EX-Z750 Digital Camera
Lost functionality Camera is about a year old. Suddenly, zoom doesn't work, Set button doesn't work and Display button doesn't work. Other than that, it takes pics and displays them. But without the Set button, I can't change settings. Any ideas?
Re: Lost functionality
I have the same problem.. happened after leaving it uncharged for more then a year. I think its a software problem.
someone know how to do hard reset/reboot?
Posted on Jul 24, 2010
Sorry, after Casio's customer no-service would not give me an estimate or even acknowledge that this is a known problem (as you can see, many others have had this problem), why would you want to send it to them and pay them more money to fix a problem with their product? Well, I didn't and got my camera fixed cheaper. I eneded up sending my ex-z850 to Tim at Tim sent an estimate upfront and was very timely in responding and then fixing my camera and sending it back. It cost around $60-70 and I have my camera back again. I won't be buying another Casio due to their lack of product support, but I'm glad to have my camera back for a reasonable repair fee!
Posted on Mar 15, 2010
  • 36 Answers
I suppose I should offer my comment as a solution?
I too have the exact same problem, with a EX-Z850, and an online search turns up others with similar Casio Exilim models, with the same problem. It involves a malfunctioning Disp, Zoom, and non-functioning Set button, with all other functions working OK. Casio Support seems to recognize the problem, and indicates it has to be fixed at one of their authorized repair centers. Start with their online system:
Posted on Dec 05, 2007
0 characters
3 Points
Some camera functions not working
Clean the zoom guide line by can of air and then try again.
Aug 09, 2012 | Fujifilm Finepix S1800 Digital W/ Camera...
Function buttons not working on canon a590
Since CHDK changeset #917 the <Alt> button can be set to PRINT (default) or DISPLAY from the "Miscellaneous stuff" / "<ALT> mode button" CHDK menu
  • If DISPLAY is selected for <Alt> button: press DISPLAY quickly it will act as your <ALT> mode button, but if you hold it down for a second, it acts like the DISPLAY button normally does
Performance chip
May 23, 2012 | Canon PowerShot A590 IS Digital Camera
For several years my C-3020 zoom camera has worked fine. Suddenly, now when I take a picture, the picture leaves when I snap the shutter. Always before the picture remained on the screen so I could see if...
In the camera menu, there should be a setting for "review" to allow you to set the number of seconds the picture remains on the screen. Also, you can always review the pictures you've taken by pressing the review button on the's usually a button with an arrow that points to the right.
Jan 21, 2011 | Olympus Camedia C-3020 Zoom Digital Camera
Zoom feature not working
So you're pressing the Zoom button but it has no effect, am i correct?
There can be 2 issues - small (dust/moisture), not small(inside button gone bad).
Small Issue: Keep the camera in sunlight(not very hot) for a while. (not loaded). Wipe off with clean lint-free cotton cloth. Keep it again in sunlight for a while. If moisture is the issue then it should go off, though i have seen in some cases it took 3-4 days and suddenly it started working.
If still no response from Zoom then the internal zoom small button has gone bad and needs to be replaced. Send it for repairs.
May 30, 2009 | Polaroid T831 Digital Camera
Will not select menu
go to SETUP menu (Page 20 in my instruction book) and set ZOOM RESUME to OFF. Then it will open up at widest setting all the time.
Aug 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Fuji FinePix S700 Problem
Try to put it on super macro and see if this will reset the zoom function.
Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom.
If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
Jun 12, 2008 | Fuji FinePix S700 Digital Camera
Powershot s31s
after 3 months the camera powers off while zooming out.
Has anyone a support servive # for Canon?
Dec 24, 2007 | Canon PowerShot S3 IS Digital Camera
Loss of button functionality
Try loading this Firmware update...
I was having the same problems and my camera works great now after loading the update.
Jul 04, 2007 | Pentax Optio S4i Digital Camera
Canon S70 does not work
I was experiencing the same problem - I think the Button and Zoom had become jammed down slightly. I simply lightly applied pressure lifting the surround of the button up! My camera is now working perfectly.
Jun 13, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
IXUS 700 zoom problem
contact customer support If has been dropped a repair price maybe well on the way to replacing the camera
Oct 30, 2006 | Canon PowerShot SD500 / IXUS 700 Digital...
Casio Exilim EX-Z750 Digital Camera Logo
398 people viewed this question
Top Casio Digital Cameras Experts
Starnley Johnwells
Starnley Johnwells
Are you a Casio Digital Camera Expert? Answer questions, earn points and help others
