Question about Datalogic Computers & Internet
DLC6065 Need to add a carriage return to the scanner
My scanner doesnt press enter after each scan
what is is the model of the scanner? What you need to do is program a suffix carriage return.
Oct 21, 2013 | HP Wired Handheld Barcode Scanner
Need to have a barcode that when scanned will simulate an enter
There is not a barcode to simulate the enter key. You have to program the scanner to add the C/R (carriage return) to the end of the data that it sends. This is just a simple programming step. The users guide that came with the scanner will have a section in it with barcodes to scan to program the unit to perform differently. Each model scanner is a little different but the process is about the same. Enter programming mode, scan the C/R barcode, exit programming mode. Now when you scan the barcode the scanner will automatically add the "enter" for you.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 15, 2010 | Symbol MC3090 Wireless Barcode Scanner
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
LS4004 Scanner displaying 2 random digits on scan?
Hello coreyog. I think I can help you with at least part of this. The "suffixing with an enter" you're describing is called a Carriage Return. If you go to your manual, you'll be able to find the Carriage Return enable and disable barcodes. Disabling the Carriage Return should fix that part at least.
As far as the digits not found in the barcode, there are about a thousand and one reasons it could be doing this. Generally, I suggest to my clients that they use the manual to reset the defaults of the scanner while plugged in to the problematic machine, after resetting, unplug the scanner and plug it back in. This should get windows to re-discover the device, as it were. This takes care of it about 75% of the time. I hope I've at least helped you get a start on fixing your scanner foibles. Good luck!
Jan 06, 2010 | Symbol LS 4004i
Manual carriage return necessary after scanning barcode
With the Symbol scanners, they usually come with a sheet at least of scan codes to configure the scanner. One of those bar codes will have the option of not needing to manually hit the carriage return. What model scanners are they? You can probably find the codes from Symbol.
Sep 17, 2009 | Symbol LS 2208 Barcode Scanner
Computers & Internet Logo
65 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
jackcity
jackcity
Level 1 Expert
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
