Question about WEIDERFITNESS.COM Weider Platinum Plus
I have a Weider Platinum XP800 Crossbow that will not start.
When I plug it in there is no response on the control board. Does anyone know if there is a fuse box or something to reset it? I tried holding down the "Next" button along with the "Motorized Weight Adjustment +" button for 5 seconds as described in the manual and it did not fix the situation.
I had the same problem. Take off the black box at the base and check to see if any of the wires broke lose from the connectors, mine did. One pair of wires was alot shorter than the rest, so when the previous owner disassembled the crossbow he lifted the unit too far before disconnecting the wire connectors thus braking the two wires from the connector. Simply remove the remaining wire bits from the connector with something sharp (unplug machine from the wall). Then take the broken wires and push them down into the connector terminals with a butter knife. The terminals will cut through the wire insulation and make a contact with the wire. Problem solved.
Posted on Sep 02, 2009
Platinum cross bow 800 xp will not power on
Posted on May 23, 2010
  • jrodjoker199 May 23, 2010
    cross bow platinum 800 xp will not power on i checked wires they are fine????
Replace internal cable weider platinum xp 800
This is a tricky job.
I do suggest calling a professional.
Because if you have to ask then explaining is very hard to do
Nov 30, 2013 | Weider PLATINUM XP800 Console
Hi, i am looking for a weider platinum exercise tape and or manual i have owners manual
The best source I can recommend is that you contact Weider Fitness and see if they such material. Since it was design to compete with the Blow Flex and they have basic exercise movements that both utilize. I have seen some Video off of YouTube even though they are 3 to 5 minutes in length it will give you a starting point.
May 29, 2010 | WEIDERFITNESS.COM Weider Platinum Plus
Learning how to set up the Weider crossbow for different exercises,I have no paperwork for this machine and not sure how to use it..
Go to iconservice.com click on to manual input weider then brand name crossbow and their is 12 manuals to choose from and I found 1 YouTube video about 3.28 mins long more of promo then instructional but it give will you an idea how to use the unit.
May 15, 2010 | Weider Nutrition Weider WEBE8077 Home Gym...
I have a weider crossbow platinum
Hello there, If you go to iconservice.com they have contact information, manuals and just about any other information you may require for your Crossbow.
Fyi the first thing I would check is the power supply itself to be sure it is putting out the correct voltage.
Good Luck! Tim
Jan 29, 2010 | Exercise & Fitness
Need excercise chart for Weider Crossbow Platinum. Available?
you can order a print here:
http://www.zazzle.com/weider_platinum_excercise_chart_poster-228106828410296215
or you can download it here:
http://www.mediafire.com/?5dzm31drljz
Oct 09, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Weider platinum xp800 gets locked in maximum weight position
open the housing in back of unit and manually turn the bar (top left)next to pulley motor until the resistance bar is all the way to the right or in the lowest wieght setting. make sure to put the weight on the console to 10lbs. now plug unit in and press and hold the next button and the + on the wieght selector for five seconds then press the + again on weight then next one more time and this will recalibrate the machine, unplug and plug back in and ur ready to go.
Aug 09, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
I have a Weider Platinum crossbow and the resistance isn't setting properly if at all. Is there a simple solution that I can do to fix this?
This is a common problem with this machine, the wiring inside the back. Mine was broken too, it was just a loose wire, but the stupid wire is so inside a protective case, you have to take the whole machine apart to be able to reach it.
You'll need a technician to come to your home. Call Icon to get a reference.
Jul 14, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Weider Platinum Home Gym - Cable Motor Stopped and Controls Blink
My son received an old Weider 8515 weight machine from a relative. The cable was worn and broke. Where would I find a replacement cable?
May 19, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
My Weider XP800 will increase in resistance but will not decrease
There is a wire that Breaks that is attached to a limit switch that is located inside the elbow of the Pivot arm. If looking from the Back of the Machine, it is on the RIGHT side. I extended the wire an rerouted it to run on the outside of the pivot arm to avoid be nicked or pinced by the moving parts.
Apr 27, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Weider platinum xp800 does not work
There is a wire that breaks that is located inside of the pivot arm that hooks to the limit switch. (If you take off the back look on the RIGHT side of the machine.) When that breaks, the weight will not adjust.
I extended and rerouted my wires to run on the outside of the arm instead of the inside where they get nicked or broken by the moving parts.
Apr 13, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
WEIDERFITNESS.COM Weider Platinum Plus Logo
2,462 people viewed this question
Top WEIDERFITNESS.COM Exercise & Fitness Experts
Tom Chichester
Are you a WEIDERFITNESS.COM Exercise and Fitnes Expert? Answer questions, earn points and help others
