Lg direct drive no power - Washing Machines
LG Invertor Direct drive dishwasher - how to stop a cycle before it is finished and drain the machine
just turn power off and back on hit start it will drain first b4 new cycle starts
Nov 29, 2016 | LG Dishwashers
The drum will not turn on a direct drive lg washer
i would guess bad bearing or broken spider. there are no gears or gearbox on a direct drive LG.
Sep 20, 2016 | LG Washing Machines
My Direct Drive front loader will not intake water
You need to verify power at the inlet water value. If you have power the value needs to be replace
Jan 10, 2015 | LG Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
Lg direct drive washing machine
Have the motor coils checked for condition, replace if short circuits are present.
Aug 28, 2014 | LG Washing Machines
Lg problem
problem with door switch bi metal,,,kindly replace door swich,
Apr 19, 2014 | LG Washing Machines
What causes an lg direct drive not to spin
your tub needs to be totally empty of water first,if it is then open the top cover and run the diagnostics on the unit,if this fails then the control board is defective
May 29, 2010 | LG WM-2277HW Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
