Question about Symbol PDT 3100
Error code 0040 - Symbol PDT 3100
  • Official Brand Answer
  • 3,100 Answers
Hi
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads for assistance.
Mark
Motorola Mobility Support
Posted on Jan 20, 2015
What is the solution to error code c004c
0040 - suction fun motor malfunction problem.Use the vacuum cleaner and clean the ventilators.
OR
Replace the fan at the top of the machine. the one that is at the top, near the optical section.
Apr 24, 2014 | Konica Minolta DiALTA Di200 Copier
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Malfunction code C0040
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Apr 12, 2012 | Konica Minolta DiALTA Di200 Copier
No problem with player just need to know how to make it region free it is region 2 at the moment
    You'll need a Palm with OmniRemote software
  1. Type in (or transfer) the memo below to your PDA
    Import it into OmniRemote with this menu command:
    Advanced-->Databases-->Import category
  2. Point your PDA towards your player put OmniRemote in TV-mode and press 0 (Zero)
Memo (Name: Category-TV): Category-TV Button name-Enter 0000 0067 0000 0000 Button name-0 0000 0067 0000 0044 0155 00ac 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0404 0155 00ac 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0404 Button name-7 0000 0067 0000 0000 Button name-8 0000 0067 0000 0000 Button name-9 0000 0067 0000 0000 Button name-4 0000 0067 0000 0000 Button name-5 0000 0067 0000 0000 Button name-6 0000 0067 0000 0000 Button name-1 0000 0067 0000 0000 Button name-2 0000 0067 0000 0000 Button name-3 0000 0067 0000 0000 Button name-Channel up 0000 0067 0000 0000 Button name-Channel dn 0000 0067 0000 0000 Button name-Last 0000 0067 0000 0000 Button name-Volume up 0000 0067 0000 0000 Button name-Volume dn 0000 0067 0000 0000 Button name-Mute 0000 0067 0000 0000 Button name-Power 0000 0067 0000 0000 Button name-Favorite 0000 0067 0000 0000
Nov 15, 2010 | Pioneer DV-350 DVD Player
What is the most common cause of an error code: 0040 and 0041 in a 2003 dodge ram 1500?
no such codes, it would be something like a po 441 or po 045. recheck your codes,good luck.
Oct 28, 2009 | 2004 Dodge Ram 1500
Error code E061/0040
check and clean the Primary Charge unit or check all the door actuator check if there is damage .it couldbe the laser gate is not opening because the (door)actuator is broken
Jul 22, 2009 | Canon CLC-700 Copier
Error codes E020/04E0 and E061/0040
Clean the thermistors and the thermofuses the first copier,to second copier vacuum cleaning the suction fan ventilator and ozone filters.
Jul 22, 2009 | Canon CLC 1180 Copier
Service required error 0001002d
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Feb 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Need multi region code for bdp 51fd
This is the only Blu-ray player that can be made region-free.You will need a professional and fully programmable service remote, like Harmony or a Palm or PDA that can support Omniremote software. The procedure may look complicate if you have not done anything similar before. You will have to reprogram the remote using a PDA or a computer.
Print this out and follow instructions here.
For example using OmniRemote™ Pro V2.01 and a Palm
1. Install the OmniRemote on the Palm, or PDA.
2. Copy the current Category to the Palm memo pad
3. Modify the "Button name-0" data with the following code:
4. Import the database in omniremote
5. Turn on the DVD Player. Press newly programmed 0 button on the palm. The Palm will control the DVD, and the DVD Player will turn off and on again. On restart it will be region free.
Sep 01, 2008 | Pioneer Televison & Video
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
Symbol PDT 3100 Logo
57 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
