Question about Hummingbird Exceed 10.0
What does exceed mean?
Ggghhhhhhhhhhk ghjhj hhjhgjk dertyu gt764es
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
What dose f90 mean
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$##%^
Jun 20, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
E000020-02b0
Refers to Magenta Drum/Developing assembly. Toner concentration within developing is low. Also can mean that the Drum Unit has exceeded its life. The code meaning will change to some degree depending on the specific model. On the Older CLC models that have Separate Developing Units the developer unit may need to be re-started. To check drum life. enter Service Mode by pressing on the Keyboard *28*. At next Screen touch "Copier", next Screen select Display. At the Display Screen select "Misc"
The drum life meters will be displayed. If the drum life exceeds 100% that could be the problem.
Mar 12, 2010 | Canon Office Equipment & Supplies
Error Code E000002-0000
E002A start-up fault is detected under any of the following conditions of the main thermistor (start-up detection fault):
after exceeding 40°C, it fails to reach 60°C within 10 sec.
after exceeding 60°C, it fails to reach 80°C within 10 sec.
after exceeding 180°C, it fails to reach 195°C within 10 sec.
Jan 19, 2010 | Office Equipment & Supplies
What does F2 mean
F2 means that the oven temperature has exceeded 590 degrees with the door in the unlocked position. There is high resistance or interference in the oven termperature sensor. Replace the oven temperature sensor.
Nov 18, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Exceed not working on office network
Well, first, what is your internet connection bandwidth?
Most of the vpns drop the connections when the speed is not good enough, and that means your application won't work fine.
Also, when you use WiFi you can transmit upto 54megabits per second only (the wired network speed is 100MBPS), unless you have wifi N.
Anyway, first I would check the internet speed/bandwidth, test with a faster one, and if everything goes fine, then you know what the problem was :D.
Mar 05, 2009 | Hummingbird Exceed 10.0
What does a po1165 code in a 2001 hyundai santa fe mean
P1142 = Load Calculation Cross Check Lower Limit Exceeded
P1165 = Bank 1, Long Term Fuel Trim, Range 1 Rich Limit Exceede
need fix ya rate okay!!
Aug 27, 2008 | Hyundai Santa Fe Cars & Trucks
Hummingbird Exceed 10.0 Logo
24 people viewed this question
Top Hummingbird Computers & Internet Experts
Les Morrison
Les Morrison
Andrew Taylor
Andrew Taylor
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
