Question about Insignia 200W Stereo Receiver
After about 5 minites stop working
After turning off for a while will work again for a few minites
Hello i have a 2000 toyota 4runner limited 4x4 . i live in maine and when i start the truck up in the morning to go to work, after the truck warms up it puts out nice heat. but after i drive it for 10...
bleed cooling system.run engine with red cap off till up to temp.replace cap before turning off engine.might have to add more coolant while running.
Feb 13, 2011 | 2000 Toyota 4Runner
Cannot get light out
It may sound silly, but it works. lay down the oven and spray the part where it screw in with Coke leave for a few minites and spray again, try turn it out now, that work believe me
Dec 12, 2010 | Zanussi ZBS963X Electric Single Oven
I press the on butten then it works good for a few minites then the contrast and brightness thing keeps apearing. I keep pulling the plug out then in and solves the problem for another 1 min then the thing...
Its more likely your cables or the monitor itself. Try replacing the cables, or try storing the settings of the monitor once you are happy with the resolution
Oct 17, 2009 | Computers & Internet
My washer will stay on for a few minits then it turns off i have to unplug it and wait a while then it works again for a few minits
Hi, this is a typical timer or , control board issue. the control sector is damaged. possibly a circuit malfunction or, a damaged chip set. replacing the timer control or, control board will fix this issue.
Jul 09, 2009 | GE WPGT9360EPL Top Load Washer
MOEN POSI-TEMP GOES FROM HOT TO COOL AFTER 30 SECONDS OR SO
Wow A Mystery Faucet!!! SOUNDS LIKE THE WATER LINES FEEDING THE FAUCET MAY BE SWITCHED. CHECK TO MAKE SURE THE COLD FEED GOES TO THE COLD SIDE AND THE SAME FOR THE HOT. SOMETIMES MISTAKES ARE MADE WHEN INSTALLING THE FAUCET. MAKE SURE THEY ARE CONNECTED THE SAME AS THE 2 THAT ARE WORKING. IF YOU HAVE THE TIME AND PATIENCE, YOU CAN TAKE A WORKING FAUCET AND INSTALL IT IN PLACE OF THE (mystery faucet) AND SEE IF YOU HAVE THE SAME RESULTS. IF YOU GET HOT WATER IN THE TEMPORARY FAUCET, THEN YOU HAVE A DEFECTIVE FAUCET. THESE ARE A FEW TROUBLE SHOOTING TIPS I HOPE THAT MAY HELP YOU.....JOE
Jan 30, 2009 | Moen & Posi-Temp Single Handle Shower Or...
It works a few minites,then stops and displays "Protect".
Your complaint isn't a problem at all. This is a usual characteristic of the relevant amplifier. The protection mode comes on when the main volume/bass/treble or whatever is too loud. Unfotunately, you can not overcome it. But, as they always say: It's a Sony:)
May 01, 2007 | Sony STR-DE545 Receiver
Insignia 200W Stereo Receiver Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
