Question about Pioneer XVDV830/SDV830 DVD AUDIO HTP System
Timer problem timer blinks
Defiant digital timer has blinking light
Installed a Defiant light timer today. Light came on as scheduled, but is blinking. When I attempt to "toggle" OFF, it only dims, does not go OFF. When I move the switch from the ON to the OFF position, the unit turns the light off. Defective timer? HELP !!
Aug 14, 2013 | Defiant Timers: 5-Amp In-Wall Digital...
My pioneer model xv-ev90 is gone in timer mode..how to fix it ?
It is gone in timer mode ..if we plug in the cable then only timer light blinks..what to do plz help me out
Feb 08, 2012 | Televison & Video
Trying to light my 2 outside lights. when wired the bulbs blink and the timer makes a clicking noise. I have a black,white and neutral wire
We are always ready to help the do-it-yourselfer.
You posted under ST01C timer.
1) Since many timers look similar but wiring is different, let me offer 2 solutions.
2) Or add a comment and say which brand and model timer you have, for direct answer. I will respond with exact information for your timer.
3) ST01C and EJ500 timers will blink and click if red and black timer wires are connected together.
Open following link to see correct wiring illustration.
http://waterheatertimer.org/ST01C-program.html#ST01C
4) Other timers will blink when white and red timer wires are connected together.
Open following link to read step-by-step how-to
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html#wiring
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a Mitsubishi WD-52725 and the timer light continues to blink and I cannot reset it. What can i do to fix this.
1. Timer LED does not stop blinking; suspect the DM PCB part # 934C152001-V28++ 2. Timer LED blinks 70 seconds, pauses then starts blinking again, suspect the E2P PCB part # 935D820001-V28+ 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition.
Feb 17, 2011 | Mitsubishi Televison & Video
Stand by\timer blinks,picture go out everytime it blink .
Blinking codes meaning:
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Good luck:
Dont forget to rate:
Jun 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
14 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
