Question about Nakamichi Car Audio & Video
Can't set the minutes on my nakamichi Na788 car stereo
Can't set the minutes..have got the hour set
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
JVC 200W CDRW KD-S30 removable face car stereo. How do I set time of day and month?
HERE IS A LINK FOR THE USER MANUAL.
http://books.jvc.com/Download/393893894/GET0174-001A.pdf
HOLD SEL FOR MORE THAN 2 SECS. SELECT CLOCK USING FF/REW BUTTON TO VIEW HOUR/MINUTE. USE VOLUME TO ADJUST HOUR/MINUTE. PRESS SEL WHEN FINISHED. PRESS DISP TO VIEW CLOCK
Aug 18, 2010 | JVC AM FM CD DET FACE CAR STEREO
Jvc KDG 440 set a time
Select clock hour, set hour with turn knob. Select minute, set minute with turn knob. To exit press SEL
May 19, 2010 | JVC AM FM CD DET FACE CAR STEREO
Soundspace3 power supply
This will fix your problem, visit Power Supply Guy on Ebay, Item # 200365155512 or copy & paste this link:http://cgi.ebay.com/Nakamichi-Soundspace-3-Stereo-System-Power-Supply_W0QQitemZ200365155512QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea6b1a4b8&_trksid=p3286.m20.l1116
May 31, 2009 | Nakamichi Soundspace 3 Shelf System
NAKAMICHI MB100 CD disfunction with the message "D-ERROR"
Try these guys based in Hong Kong. SunLight Car Stereo Co Ltd (sunlightltd@yahoo.com)
Jan 15, 2009 | Nakamichi MB100 Mobile Tuner / 6 Disc...
Change the time
make sure the time is displayed and press the "set" button. once the time starts flashing use the "preset" buttons to set the hour and the "volume" buttons to set the minutes. press "set" again when done.
Mar 14, 2008 | Nakamichi SOUNDSPACE 1 CD Player
How do I set the clock???!!!
Come on, someone, pleeeeease???
It's driving me crazy.
Nov 06, 2007 | Nakamichi CD-35z CD Changer
Clock
1.While the unit is off, keep the CLOCK button depressed  and press HOUR adjustment button to set hours.
2. Repeat with MINUTE button.
Also, you can get a manual for the unit from Nakamishi. They will want the serial number of your unit.
I hope this helps.
Toothman 1
May 30, 2007 | Nakamichi CD-400 CD Player
Car Audio & Video Logo
54 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Mohamed Ismail
Mohamed Ismail
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
