Question about Yanmar Generators Yanmar YDG 5500 Diesel Generator
No power due to busted avr - Yanmar Generators Yanmar YDG 5500 Diesel Generator
Avr 55 wont power up
units in protection due to fault check speakers
Nov 30, 2014 | Harman Kardon AVR 55 Receiver
My 20^ iMac do not turn on. Help!!
Relax. Check the cord if it is connected properly. It might be that the plug is loosed, some wires are open or the outlet is defective. Try to plug to other outlet. If the problem persists. Look at the power diode if it is off the power supply is defective. Listen to the fan in the power supply inside the casing if it is working. If it is not, then the fuse is busted. If you can take the busted fuse out then ok otherwise, you the service of the technician. If you have AVR connected to it, check the AVR if it is working, check if the switch is on, the lights on etc, same thing also with UPS. Contact me then if the solutions are not working.
Jan 31, 2011 | Apple Computers & Internet
All of a sudden my compuyer won't turn on at all, I checked everything that plugs in but nothing
  • check your AVR / UPS
  • possible busted power supply, you will need to have it replaced
Oct 04, 2010 | Computers & Internet
Hi my power in my house went out today. When I got home my computer is off, no lights no nothing. Help
Check if the power cable was properly plug into the power outlet.
If you are using a AVR, or a voltage regulator, double check if the unit fuse was not busted. Due to some power outage and any abnormal power input on your area, the fuse will be the to down cause this parts will be the one absorb the power failure and not directly to the appliance.
Let me hear from you here again.
Thanks
Apr 06, 2010 | Dell OptiPlex GX520 PC Desktop
Hp pavilion 1230n will not turn on
try to check the wall power outlet if have power output, if have ,try to check the avr if the led lights up if not try to check the fuse of avr maybe its busted, if not, try to check the power cable that used to plug to system unit if have power output use multitester and if have, replace your system power supply.
Oct 11, 2009 | HP Pavilion a1230n (EG134AA) PC Desktop
Monitor screen shrinks!
The problem is due to under voltage.You may have an unstable power or your computer auto voltage regulator (AVR) is not doing its part..If not then you have a busted capacitor..resolder all capacitors and replace ruptured capacitors with same value and ratings..
Jul 19, 2009 | Computers & Internet
Powers on 5 sec then powers off
if it goes off even with no sound, system is put on stndby protection mode. something wrong with your output section. busted power output xtors of IC.
Mar 17, 2008 | Audio Players & Recorders
Does not power on
Hi Mia,
Hope this tips can help figure out the problem; If AC mains or AVR is good, review checking the power cable connecting from AC mains/AVR best fittingly. Or try connecting the monitor on different outlet. Just be careful in handling connecting end to AC source always. Try another cable if you have extra one. If the problem persist there might be internal problem on your monitor. Busted fuse or cold solders before you transport causes the problem. You'll need technical guy to check internal of the monitors due to high risk of Voltage Shock. Please be guided.
Best regards,
Rosener Guyano
Jan 30, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Yanmar Generators Yanmar YDG 5500 Diesel Generator Logo
Top Yanmar Generators Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Yanmar Generators Electrical Supply Expert? Answer questions, earn points and help others
