Question about Polti Lecoaspira 712 Steam And Vacuum Cleaner
The steam works but the vacuum cleaner does not work
The steam Works but the vacuum cleaner does not
Does this cleaner heat up the water for steam? It is called a steam cleaner, but I do not see anything about how to regulate the temperature of the water to make the steam and so no one gets burned.
Steam is steam is steam - it has a temperature of 212 degrees F and if you go any lower it is no longer steam - condenses back to water. Capiche? If you pressurize the steam you can then raise its temperature to a super heated condition. How do you think a pressure cooker works??????
Aug 26, 2017 | Vacuums
Steam cleaner sc20
It works like a squirt gun, submerge complete unit into water to add water. After it fills pull out and ready to use.
Jul 28, 2014 | Conair SC20 Handheld Steam Cleaner
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
WON,T SPRAY CLEANER/WATER CARPET IS DRY.THE TOOL ATTACHMENT WORKS OKAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 08, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Shark steam cleaner just stopped working - doesn't make steam anymore. Is there a way to fix it.
I have the same problem - just heard from the support tech to soak the "device" in 1/2 vinegar and 1/2 water. Read on line a customer used vinegar in the device itself, heated it up until it made steam, then emptied it and used distilled water and it was fine. I haven't tried it yet, so we'll see if either solution works . . .
Mar 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a bissell steam cleaner. the hand piece
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
a
Sep 26, 2009 | Bissell 1699 ProHeat Clear View Upright...
Shark Steam Canister S3325 will not turn on when switch pressed
I had a similar problem; disassembed switch and clamped electrical bayonets tighter with a pair of pliers; works good now.
Mar 21, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
Eureka Atlantis 2591A Upright Steam Vacuum
if it drips out while the tank is off the machine it couldbe the spring load mechanism in the cap. try soaking it in hot water for a few minutes to swell the rubber then with a pen push the spring plate up and down to lubricate the rubber. then try and see if that works. usually they are gravity fed systems but only works when the tank is in the unit.
Jun 08, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Polti Lecoaspira 712 Steam And Vacuum Cleaner Logo
19 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
