Question about Concept Chameleon 10.1" Wide Flipdown Digital TFT LCD Monitor w/ DVD
Not getting any power, so i need to know how to power it
It came with the car i bought but has no manual let alone power to see if it works.
Need to convert a Power Supply CISCO 34-0873-01 to work stand alone??
These should use a standard ATX pinout. Use the big 24 pin moles connector to bridge pin 14 to 15. http://www.techpowerup.com/articles/other/22
Sep 30, 2012 | Sony Lot Of 2 - Cisco Catalyst 4000 Series...
Ddx 419 no sound ipod
No offense but this is actually not the solution. There is a quirk with some Kenwood DDX 419. The manual on page 24 makes it clear that it is supposed to play audio through an ipod cable alone, only if you want to stream audio and video or the Garmin App should you need the other cable with the dual plugs (usb and audio). I bought one for my car and had it installed last week and it works right from the USB (only) with my iphone 4s and does not need the extra audio plug in which is inferior sound quality (analog) compared to the USB only (digital). I bought a second deck for my wife's car and had them install it this week and it did not work with the USB alone. The one on demo in Future shop did not work either with the USB alone. The manual for the DDX 419 makes it clear that it is supposed to stream audio without the extra cable. It reads, "To listen to the music (digital): USB Audio cable for iPod/iPhone-- KCA-iP102 (optional accessory). Look up the cable by google searching and you will see that even on the Kenwood site it is a regular iPod/iPhone cable. There is obviously a glitch with certain decks and they are not addressing it. I am returning mine and getting a Pioneer.
Aug 24, 2012 | Kenwood Ddx-419 6.1" In Dash Double Din...
Need owner's manual on 2004 Terry Quantum Fleetwood Trailer
When I plug my terry I don't get power but I get power from my battery the power source work at the camp site but I'm not getting power can any help me
May 19, 2010 | Electronics - Others
Convert window from manual to electric
You would need electrical know how to use the fuse block to get power. Otherwise get power directly from the battery but go through an inline fuse about 20 amps. The fuse needs to be at the battery that way if there is a short power stops before you start a fire!
Apr 02, 2010 | 1986 Toyota MR2
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Bosch stand alone freezer Intelligent 32 - how to defrost
Hi
I have the same refrigerator and found the manual;
"The refrigerator compartment was programmed to defrost automatically meaning you do not have to constantly clean and dry it. Copy from the manual"
Also have a look in the back for the drain outlet - very small. If that is clogged up it also cause water on the inside.
Feb 28, 2009 | Bosch KSR34464 Refrigerator
I have a Nissan Blue Bird ARX model and have changed the engine and the radiator. My issue is with the mileage. The previous mileage used to be 180,000 and the second hand engine which I've got fixed is...
leave the milage alone when you sell the car show proof with date that you did the work you'll advertise and good luck paper reciepts work well.
Dec 20, 2008 | 1993 Nissan Altima
Concept Chameleon 10.1" Wide Flipdown Digital TFT LCD Monitor w/ DVD Logo
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
