Question about Whirlpool GEW9250 Electric Dryer
My dryer has power but just humms when i push the on button. no tumble no nothing
  • 27 Answers
The belt is broken
Posted on Jun 15, 2009
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
I have a affinity dryer that just humms when I turn it on. I have power 220 at recpt. no code reading?
Sounds like the motor could be locked up, Is the dryer turning if not belt broke , Check belt, take the front access plate where the motor is located and turn it on check to see if the shaft of the motor is turning at normal speed and again check the belt, with power off and belt is not broken by hand turn the drum to make sure nothing is blocking it from spinning freely. if that is free and clear than my bet is on the motor itself as it sounds like it is in locked rotor.
Cause's of locked rotor
Motor seen its better days
if equipped the start/run capacitor could be out
Hope this helps.
Mark
master Electrician
Sep 19, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Whirlpool dryer. When pressing the start button the motor humms. It keeps humming until opened or unplugged. Does seem to generate heat though.
maybe a broken belt, here is a website that will assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 13, 2011 | Whirlpool LGR7648KQ Dryer
Dryer is humming when I push the start button, nothing else.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Electrolux tumble dryer
Power it down and then restart. Turn breaker off
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 27, 2009 | Dryers
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Dryer not tumbling
Broken drive belt, or drive belt disengaged. Or stretched. Or lost tension spring. Humming is motor running, not driving drum.
Jan 21, 2008 | LG DLE5977 Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Nov 03, 2007 | Amana DLE330RAW Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
89 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
