Question about Canon imageCLASS MF4270 All-In-One Laser Printer
Full form of CIS unit in canon printer - Canon imageCLASS MF4270 All-In-One Laser Printer
Canon inmage class mf3010 E202 service error
E202 CIS Unit home position detection error / homeward reading position error When the same error repeatedly occurs although the power is turned OFF and then ON for several times, execute the following remedies.
(1) Check the connection between the Main Controller PCB and the CIS Unit. (J2)
(2) Replace CIS Unit.
(3) Check the connection between the Main Controller PCB and the Reader Motor (M3). (J11)
(4) Replace the Reader Motor (M3).
(5) Replace the Main Controller PCB.
Mar 27, 2015 | Canon Office Equipment & Supplies
How to solve system error e225 i-sensys mf4330d
it is indicated as a service man error code in the form of "SYSTEM ERROR E+number."
E225 CIS (Contact Image Sensor) lamp has a fault. - Turn the power OFF and then back ON..
- Replace the CIS unit.
Jun 07, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf4320d getting error225
CIS scanner lamp has fault, replace the CIS scanner unit.
Feb 08, 2013 | Canon imageCLASS MF4150 All-In-One Laser...
6system error E225
this is common problem in this canon printer
1.you can clean the top of the glass with soft cloth and try.
2.you have to open the scanner top class and you can find a scanner cis unit .you can clean the top of this unit (be careful this unit is very sensitive)
3. you have to change the scanner cable if found damaged.
4.you have to change the scanner cis unit
Aug 08, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
I am having a problem with one of my Printers, it is a brand new printer, Model Canon Image CLASS MF 3222. It was running alright for about 2 weeks, now it displays on Printer LCD ( System Error 225 ).
E225 - CIS lamp has a fault.
- Replase the CIS unit.
Before any replacement - try to check all cables for wear and all connections of scanner.
May 23, 2011 | Canon LaserBase MF3220 All-In-One Printer
Error 225 in canon 4350 imegemanage printer pls sent solution
E225 is the error code regarding the CIS unit malfunction. First reconnect the flat cable to the CIS unit. If still problem is existing do the following steps in the service mode press "Additional function"," # "( to enter the service mode) Use the arrow keys to scroll to HARDWARE TEST, press OK Use arrow keys to scroll and select CIS TEST, press OK Now as shown in display press 1,2,3,4 and check if the CIS is glowing in White, Red,Green &Blue. If CIS is not responding, it's time to replace the CIS unit. If the CIS is responding properly do the following procedure.
Now dismantle the scanner section and apply a suitable lubricant( Silicon oil can also be applied) to the portion of the flat cable which touches the bottom plate and also to the portion of the bottom plate over which the flat cable is sliding.
If still issue not solved it's time to replace the CIS unit
May 19, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Hi, when i start my print canon mf4010, it show me in the image book system error e225, i don't know why, please help me. thanks IMJA
PROBLEM REGARDING CIS UNIT(SCANNER) Reconnect the flat cable to the CIS. If still problem continues, apply lubricant to the flat cable where it touches the bottom and to the bottom plate over which the cable is sliding. Check if there is problem still. If still there is problem. Replace the CIS Unit
May 19, 2011 | Canon Office Equipment & Supplies
System eror e225 on canon 4320d
it is related to your CIS unit and SCNT Board.
it can be solved by upgrading also.
try to check this two units. 1) CIS and 2) SCNT Board.
Apr 29, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mfp 4320d system error e255
dear sir,
this is manjunath my canon laser jet printer it's given problem the problem is system error E255. it's shown on the printer.. plz given the sulation... my contect number is +91 9916062560
Jul 08, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF4270 All-In-One Laser Printer Logo
130 people viewed this question
old marine
old marine
