Question about Electric Garden
How to free a stuck electric mower motor - Electric Garden
Starter cable is stuck
unscrew top and check recoil drum if doesnt turn back possible broken spring following links should help
An easy way to fix pull start recoil spring How to Replace the Recoil Spring in an MTD Motor Lawn Mower About com Search Find it now
Jul 27, 2016 | Garden
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt c
Stuck brushes,in the brush holders caused by corrosion,unplug the cord first,remove the cover and look for two carbon brushes that should be contacting the motor,if not stuck they may need replacement !
Sep 28, 2014 | Garden
Can i fix small electric motor
Most electric motor problems are caused by the bearings failing. Before that happens it may get very stiff but stil turn. With the power off, and the blade still attached, try turning the blade at least half a turn. Is that possible? Any noises as you turn? Is it very stiff or fairly free? If you turn it several times you may find that putting it upright and connecting the power it may start turning again.
Let me know what you find.
Jul 04, 2014 | Electric Lawn Mower
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Jcb electric mower just makes clicking noise wont start
some of these mowers have reset buttons on the motor---it works like a circuit breaker---access the motor housing to check for a button
May 10, 2010 | Acer Lawn Mower
Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Mar 03, 2010 | Black & Decker 19" Electric Lawnhog...
My wife cut the front lawn with our Craftsman electric mower. When she moved it to the back yard it wouldn't start. I checked the cord, bought a new switch that is in the safety handle but nothing works. I...
Do you get a hum or any noise when trying to sart ?
Motor could be stuck..
WHILE UNPLUGGED - try spinning the blade by hand & see if its not stuck..
Jul 08, 2009 | Electric Lawn Mower
Won't Start
theres a 25 amp fuse inbetween the battery and starter, also check your safty swiches like the seat, clutch/brake and blade disingadged
May 30, 2009 | Garden
My electric lawn mower starts briefly and then trips the circuit
check cord from plug to the electric motor.if it has a reset or breaker check for damage. if no obvious damage problem is electric motor.may be cheaper to buy new 1
May 06, 2009 | Electric Lawn Mower
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
15 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
ray gallant
Are you an Electric Garden Expert? Answer questions, earn points and help others
