Question about Pentair Minimax NT Heater
NT mini max not heating at all - won't fire
We have a mini max NT heater on the pool - 5 years old.  It won't heat.  We have replaced the combuster (blower) and that didn't fix it.  The part was very rusted though.  Replaced the ignitor and it still doesn't work.  Now pool guys says it is the burner but he isn't sure he can get a new one installed so recommending new heater (Ouch).  Is there another way to fix\troubleshoot this problem.
  • swolters168 Aug 24, 2009
    Too late. Had to replace the whole heater. Very expensive. Better luck next time. Thanks.
  • poolyoda May 11, 2010
    I need more info. Does the fan come on. Does the ignitor glow?
    Champion:
  • 246 Answers
Wow t pool service is just guessing i guess . weel let see do u have a pilot if yes do u hear a click if yes clean t burners if not check 24v at t brown wir e for t gas valve if v replace gas valve if not replace ignition control . do u have any code on t back or t front this help a little.
Posted on Sep 18, 2009
Why is this Pool heater making a very loud whistle sound after heater is fired up.
sounds like a leak in the air stack or if coming from gas valve need new gas valve
Aug 28, 2014 | Sta Rite Pool & Spa
When I turn my mini max plus 400 heater on it clicks then nothing happens, what's up with that
If it is clicking it is trying to fire (calling for heat). This indicates that the internal safety loop Tstat, and IID are working. It is either a bad gas valve, your ignition wire, or lack of gas. If the gas line had been open for servicing for any length of time it can take a while for all the air to get out. Best call out a tech to do the repair, you are literally playing with fire.
May 15, 2012 | Pentair Minimax NT Heater
I have an mini max nt w 6800 controls ignitor
The voltage to this ignitor should only be 120 volts. If you are getting 240 volts to the ignitor, there is something really wrong with the wiring to the heater or in the heater.
Jul 27, 2011 | Pentair Minimax NT Heater
I let my pool heater freeze
Once a Pool / Jacuzzi heater freezes they will haunt you again and again. You fix one leak and weeks or months later another one appears. Sometimes the only damge done is just the manifold gasket. It would be worth HANDS ON repair "estimate" to find out if it is the manifold or the heat exchanger that has failed. If the heat exchanger has failed BUY A NEW ONE.
Jan 24, 2010 | Pentair Minimax NT Heater
Mini max 150 has pilot lit but will not heat
If you read Ohms across the TH circuit with the thermostat(s) turned up and the switch in the on position with the pump running you should have about 1.0 Ohms. Anything higher than 2-3 Ohms and you have too high a resistance reading and will need to find the bad part/connenction. If you have about an Ohm and the burners are not lighting be sure you have enough voltage off the generator. With no call for heat it should read around 500mV. Once you turn everything on it should drop to about 300mV.
If all these reading are correct try striking the gas line near the valve. The solenoid may be sticking. If it frees up you may get more use from it. If not, the valve needs to be replaced.
Jul 28, 2009 | Pentair Minimax NT Heater
I have a Pentair MiniMax NT heater about three years old. The unit is making a loud "popping" sound when heating. I think its the heat exchanger from what I am hearing. Can a heat exchanger be cleaned out?...
the heat exchanger can be reamed or replaced but it is quite a job; replacing the heat exchanger is very expensive and time consuming. unless your pool chemicals are extremely out of balance, most especially low ph from using tablet chlorine or too much acid the heat exchanger should not have worn out this quickly. the best solution if you do not have a pool serviceman is to call Leslies Pool Supply or a trained Pentair service tech. It may be worth the service call to have the problem diagnosed by a pro.
Jun 24, 2009 | Pentair MINIMAX NT TSI IGNITER
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Pentair Minimax NT Heater Logo
420 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
