Question about Canon BJC 80 InkJet Printer
How to print from Window Vista to Canon BJC80 printer using USB to Parallel cable
Having problems printing from Window Vista 32b laptop to Canon BJC80 printer, when using BAFO BF-1284 USB to Parallel printer cable.
  • Helen
    Helen Mar 19, 2014
    Yes, the Canon Bubble-Jet BJC-85 (when BJC-80 was selected there was no reaction at all), printer icon is showing with a green ready tick inside the Printers folder. It also has the virtual Microsoft XPS Document Writer next to it.
  • Helen
    Helen Mar 19, 2014
    What it does is that when I try to print anything from the laptop, it keeps on printing test pages non-stop or about a quarter of page.
    Master:
  • 966 Answers
Helen, is the printer correctly installed in laptop? Check if shows under Printers and devices. If not, install and show it as default. Make sure your usb connections are ok.
Posted on Mar 19, 2014
SOURCE: Canon Printer LBP-800 with Win XP
where can i download Canon LBP800 driver?
Posted on Apr 30, 2008
SOURCE: BJC 80 Won't Print
Try disable bidirectional support
Posted on Jun 02, 2008
SOURCE: slow printing
I'M USING MY BJC 80 ON A PACKARD BELL M35-U-57, VISTA HOME BASIC. CONNECTED THE PRINTER WITH A GENERIC USB-PARALELL CABLE, NO DRIVER. FIRST HAD THOSE 5 TO 7 MINUTES DELAYS FOR PRINTING. WENT TO THE PRINTERS "PROPERTIES", "ADVANCED OPTIONS" AND TICKED "PRINT DIRECTLY", IN THE "PORTS" SECTION I DISABLED "BIDERECTIONAL PORT". IT'S WORKING SWEET. NO MATTER THE QUALITY. ANY COMMENT OR SUGESTION: decoy424@gmail.com
Posted on Feb 01, 2009
SOURCE: compatibility of parallel and usb
I have Canon LBP-800 laser printer with parallel prot and have computer with USB port.
I connect my LBP-800 printer with Parallel and USB Converter but printer is not functioning. I am using Windows XP.
Please solve the problem in details.
Thanks
ishaq
Posted on Apr 17, 2009
SOURCE: Canon LBP 800 and Vista
To solve this problem i used VMWare with Windows XP (also Ubuntu worked fine):
1. Install LBP-800 on vistual PC use real LPT1 and virtual one.
2. Set Cannon LBP-800 share mode.
3. Setup workgroup network:  my real computer and virtual.
4. Install LBP-800 on my real PC as a network printer
Posted on May 15, 2009
I have a Canon BJC 80 InkJet Printer. I have it connected to my laptop using a parallel USB cable. The problem I'm having is that whenever I try to print anything, it will sit there for about 5 minutes...
I could be wrong but it sounds like a communication error between your laptop and the printer, I would check that your Canon is compatible with being connected via a USB to parallel cable. If you're running a network you could install the printer onto a PC that has a parallel connection output and then share the printer. More info can be found at this link.
Oct 04, 2010 | Canon BJC 80 InkJet Printer
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
I have a canon bjc 80 connected via usb to acer laptop with vista on says hardware successfully installed & sounds like it is printing but will not feed paper or print !! have not used a disc to install...
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge.
Feb 19, 2009 | Canon BJC 80 InkJet Printer
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
Window vista
You first need to get a Parallel Printer to USB cable. Once you have that, in Vista, click add a printer, do the windows update, and Epson Stylus Color 1520 should appear. Now you need to make sure that the port being used is the Virtual USB Printing Port, for example USB001....and there you have it...
Jun 25, 2008 | Epson Stylus 1520 InkJet Color Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
59 people viewed this question
old marine
old marine
