Question about Microwave Ovens
Jenn air jmv8208dp00
Blown bulb inside
Hello, i'm looking to replace my light bulb in my jenn-air microwave oven modeljmc8130dds. any help would be greatly appreciated.
The lamp is inside the oven so it is necessary to remove the cabinet but be aware that dangerous voltages are exposed even with power disconnected.
Oct 22, 2016 | Jenn-Air Microwave Ovens
Tip
How do I replace light bulb on my Jenn-Air microwave?
Hi.
You will need to partly disassemble the oven by removing the outer cover held by screws (the cover part 2 on the first diagram). once there you will see the bulb hand side, located on the right (the bulb is part 6 in second diagram).
Before disassemblying the appliance disconnect power, by tripping circuit breaker or unplugging the power cord.
Here the replacement part for the model JMC9158AAS, listed in title: PS391758 .
Diagrams below are also for Jenn-Air JMC9158AAS.
If you have a different model, use the links listed here: Where do I find parts and diagrams for my appliance?
Here the diagrams. Click on the pictures to enlarge.
Diagram 1:
Diagram 2:
Unless you are a technician or a trained DIYer, better ringing the number listed on the owners manual to call service support. A badly assembled microwave will be dangerous for your health. The capacitor inside the microwave can also release dangerous discharge, take care and observe safety prescriptions while disassembling.
Regards.
on Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
Jenn-air jmv9169ba will not heat
I hope you are a technician as there are lethal voltages inside a microwave , you could also inadvertently expose yourself to microwave radiation if protective switches are disabled or the door seals are damaged .Open the microwave top cover, disconnect the two wires going to the Power Transformer (The Big one) and connect a Dummy Bulb and Power up if the Bulb goes ON and OFF according to your settings, the control Panel is OK, or else replace .Check the High voltage diodes, Protector Diodes and the high voltage capacitors , if they are OK the magnetron is suspect. The high voltage transformer rarely fails. If the microwave is of the inverter type , forget it, it is not for amateurs to repair.
Jul 08, 2014 | Jenn-Air JMC7000 Microwave Oven
I have the Jenn-Air microwave oven. It is mounted in a cabinet. How do I replace the light? Should I try to remove the microwave from the cabinet? If so, how is this done. The manual is vague on this. It...
Most microwaves are similar in design, and here is how for a GE, which will most likely apply to the Jenn Air:
http://forum.appliancepartspros.com/microwave-repair/84864-microwave-lightbulb-replacement.html
This site explains the process:
http://forum.appliancepartspros.com/microwave-repair/165-microwave-interior-light-bulb-replacement.html
To discharge the cap, you can touch an insulated screwdriver across it's terminals, but just avoid the contacts and you will be fine.
Sorry to have to relay tough news, but how this helps you repair it.
Sep 10, 2010 | Jenn-Air Microwave Ovens
HOw do i replace the inside bulb?
Hi. I just told you, there is no acces for the bulb in microwaves. Bulb replacement is not supposed to be a user level maintenance operation. You will need to remove the microwave outer cover to replace the bulb.
Here again my instructions: How do I replace light bulb.
Regards.
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
Broken light bulb
Go to an appliance parts store to get the bulb.
Good Luck and Please rate fixya!
Feb 23, 2009 | Jenn-Air JMV8208A Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
