Question about Oreck Ironman Vacuum
My oreck ironman comes on but shuts off a few seconds later. Appears to run fine other than cutting off.
Think it may be an internal fuse or thermal cutout. Please advise.
It is the switch this is common for these vacuums and a new switch will fix it I come across this problem a lot when I am repairing vacuums
Posted on Mar 21, 2014
I changed the roller brush on my Oreck XL Insight vacuum and now when I turn it on it only runs for about 5 seconds and shuts down Any ideas
Bigme03,
It sounds like you may have been given the wrong brush roller. Several models of Oreck's have a sensor in them that watches for the brush roller turning at the proper speed. The way they do this is by mounting a magnet into the brush roller and the sensor counts the number of times the magnet passes. If that magnet is not there or if the sensor does not detect the magnet passing, ie..a broken belt, it will shut the motor off. The only way you can fix it is to get the correct brush roller and put it back in. Hope this helps!
Mar 07, 2015 | Oreck XL Insight Upright Vacuum
Why does my Oreck upright. Acumen keep shutting off after a couple of seconds?
Atek,
Sounds like you have one of the Oreck's that has a sensor that looks for the brush turning and you received the wrong brush. Look to see if there is a metal ball embedded in the wood about a quarter or a third of the way down from the end opposite the belt end. If there is not the metal ball, you have the wrong brush roll. Getting the proper brush roller should make all the difference for you. Hope this helps!
Feb 24, 2015 | Oreck XL Platinum Pilot Bagged Upright...
Ironman canister won't turn on. took it apart to look at switch and wires. nothing loose, but checked everything... then it worked. today... no signs of life...?
The switch may be failing. You can check switch continuity and operation while the machine is disassembled but it is likely to wait until you have reassembled the machine to fail again.
Feb 13, 2015 | Oreck Vacuum Ironman Canister Vacuum Bags
How do I open an Oreck Iron Man?
There are quite a few screws that hold that unit together. A couple of them are under some "buttons" that you have to remove to access those screws. Hope this helps!
Feb 12, 2015 | Oreck Ironman Vacuum
Does the Oreck xl handheld vacuum have a fuse?
They do not have an internal fuse. You probably have a problem with your power cord or the switch.
Oct 11, 2014 | Oreck Vacuums
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
No power
The motor will have a thermal cut out,however chech your plug fuse and the cable as it enters into the off on switch. its known to snap here within insulation.....
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
ELECTROLUX C101H JUST SHUT OFFWHILE WIFE WAS VACUUMING, DOES THIS HAVE AN INTERNAL THERMAL OVERLOAD SWITCH ? HOW TO OPEN UP CANISTER TO SERVICE ??
it does have an internal thermal overload device you need to put the vacuum into the shop they should be able to fix it in a few days
Aug 01, 2009 | Electrolux Guardian Bagged Canister Vacuum
Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Possible reset on Thermal Cut-Off
This is not really expert advise but I have a vaccuum with hepa filters and if the filters get dirty My vaccuum acts like your what you are describing.
Jan 07, 2009 | Eureka Vacuums
Vacuums Logo
229 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
