Sonykv21tsr1 no display then horizontal position problem
  • 2,013 Answers
This is a very old device, and would probably cost more to fix than it is worth.
Posted on May 28, 2014
How to clear E000051-0000 in IR3300 Photocopy Machine
E051-0000- At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main Cause- The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO:Connect the connectors.
2. Sensor lever (damage and interference),
Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES:
a. The horizontal registration assembly is out of place because of damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty.
Replace the motor.
NO: Replace the DC controller PCB.
Aug 17, 2016 | Canon IR 3300 Digital Copier
My IR 3300 display E000051-0000 please help me...
E051
0000 At start-up, home position is not detected when the horizontal registration
Main cause The horizontal home position sensor is faulty. The horizontal registration
Action
1. Connector
a. DC controller PCB (J304) relay connector horizontal registration
b. DC controller PCB (J304) relay connector horizontal registration
motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
YES: a. The horizontal registration assembly is out of place because of
sensor.
PCB?
YES: The horizontal registration motor is faulty. Replace the motor.
As You can see, is better to call service.
Hope that helps!
Aug 01, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Display switched from horizontal to vertical while monitor is in the horizontal position. What keystrokes are necessary to return the display to horizontal?
Try pressing these key combination:
1. CTRL + Arrow Keys
2. ALT + Arrow Keys
3. CTRL + ALT + Arrows keys
These are shortcuts defined by your Video Card's support programs like NVidia or something alike.
The arrows key directions determine the direction to which the screen will rotate.
Jun 05, 2010 | HP w2207 Monitor
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
sensor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Panel stuck in horizontal position with system operating
We can fix any problem with the Pioneer AVIC. Please check out www.turbotunes.com for the best deals in your AVIC repairs.
-Steve
Jan 05, 2009 | Pioneer AVIC-N1 Car DVD Player
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Display adjustments
Is the H. Position not showing up in the menu? Or is it that you can't seem to get to the Horizontal positioning that is the problem? Usually there are 4 keys: Auto, <, >, and Menu (I'm NOT counting the power button of course) Menu starts off the process while the < and > get your through the menu. When you see the V. Position, hit the "menu" key and the H. Position should pop up.
Mar 26, 2007 | HP P1110 21" CRT Monitor
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
