Canon IR ADC C2020 E000025-0330
This copier make me crazy. Replace the toner feed assembly and all drums for news. Later sow me error E020-1060. Apply the technnical publication TP13455.pdf (http://www.copytechnet.com/forums/at...6&d=1387646470) and continues with the same error. Replace the old drum and shows me another error E025-0330. I do not know what else to do. Who has an idea how to solve these problems?
SOURCE: Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Posted on May 20, 2009
  • 133 Answers
SOURCE: showing drum error and replace toner low message all the time
Open the cartridge cover
push "option"
and push "00"
wait until the word "accept" then close the cover,
after that should be working perfectly.
Posted on May 22, 2009
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
Patzky
  • 240 Answers
SOURCE: MFC 9450 - CDN shows toner end of life message.
You can reset the toner bias by opening the front cover of the printer so that you can see the toner cartridges and then press "clear/back".
This will access the toner reset menu and you can select which cartridge you are reseting.
Thanks,
Pat
Posted on Mar 29, 2010
  • 18 Answers
SOURCE: The print on my Canon
There is a possibility that there is toner burnt stuck on the fixing roller.
Posted on Dec 22, 2010
Canon ir 2230 giving me an error E000024-0001 how to solve this porblem
That code means problem with toner sensor in developing assembly, try cleaning it out the best way u can, if that does not help you will probably need to replace toner sensor itself. (Toner Sensor FK2-0358)
Dec 22, 2016 | Canon IR 2230 COPIER FOR 220 VOLTS ONLY
Hi, I want to know about Canon Image press 1110/1125/1135 these copiers use which type of toner. Can we put IR 5000 or IR 7105 toner in them How is the drum
no you can not, the toner in a image press is a dual component toner. in the 5000 and 7105 are a mono component toner please dont and if you did please tell the tech because it will drive him crazy trying to figure it out unless he is a veteran in the copier business.
Oct 17, 2015 | Canon Office Equipment & Supplies
E000280-0004 and e000025-0200
e000280 is a fan error check this at side door
e000025 is a toner error .an unmatched toner in m/c plz replace with another toner .before u install a new toner clean the devoloper unit
Mar 24, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
What is the permanent solution for error E000020-0000. At present we are clearing the error using *28* and re-start. But it will reappear soon. Kindly advise. Technician is of the opinion that toner is...
This problem was in with the IR-C3200 problems. The E020 codes have to do with either toner or the color drums. This is most lilely an error with one of the drums. The fist 2 digits indicate the color of drum. 01 is Black, 02 is Magenta, 03 is Cyan, and 04 - Yellow.
For the IR-3530, then you have a problem with the toner. The error code in the book says that the path between the sub hopper and the developing assembly is clogged with toner. This assembly will have to be removed and checked for the obstruction. Hopefully you don't have a finisher on these copiers because you will have to remove it to get to the toner hopper assembly. Good Luck.
Mar 02, 2011 | Canon imageRUNNER C3200 Copier
E019 in canon copier 2016 j.the machine runs n at last error comes E019, may be toner censer has problem how can i solve this.where would be the censer pls help me .
You need to replace the drum unit. The E019 error code means that the Waste Toner is full, but the problem with this model is that the waste toner cartidge is built in the drum unit so you have to replace the whole drum unit.
Nov 11, 2010 | Canon iR 2016i Black and White Copier
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Jul 06, 2009 | Panasonic WORKiO DP-2330 Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
43 people viewed this question
jasbo
jasbo
