Sylvania SMPK8858 MP3 Player Logo
Y
Youmu Konpaku Posted on Mar 19, 2014
No way to upgrade software
I can't upgrade my firmware. I connected to my computer, and then I look for how to upgrade it. Anyone know how?
1helpful
I ve a JVC radio DK3, now it's showing upgrade disc.i need a software to upgrade it.Anyone to assist me please ?
Paul, Check the attached links, firmware updates.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Firmware Updates
http://support.jvc.com/consumer/custrel/index.jsp
Downloads
JVC MX DK1 DK3 DK5 DK15 DK51 FIRMWARE UPGRADE FILE Service Manual free...
How to upgrade the software?
You may want to make the effort to call toshiba customer service.
1helpful
3answers
2answers
Router drops my speed from 8 to 1 mgs when I connect to internet. Works fine when hardwired.
This router ( WRT160N ) has issue with the firmware.
It is recommended that you should upgrade the firmware of the router. Firmware is the software of the router.
connect the computer to the router with the Ethernet cable. Do not upgrade the upgrade using the wireless computer. Download the firmware of the correct model number and version number.
Once you upgrade the firmware of the router, you will need to reset and reconfigure the router according to the Internet service provide.
Click here for more information about router and network
I have to constantly reboot the router to get on the net ...what is causing this ?
I trhink you can try to upgrade the firmware of the router.
Firmware if the software of the router.
Did you try to connect it directly to the modem.
you can connect the computer directly to the modem and check whether it is working properly through the modem.
If you need to restart the modem constantly then it could be the issue with the ISP or the modem.
Click Here to know how to upgrade the firmware
2answers
E61i - Firmware upgrade failed - USB port is now bad
visit the svc centre for nokia support, thay can update the software.
Oct 24, 2008 • Cell Phones
3helpful
3answers
Nokia e61i software upgrade failure
hey friends..i just sent my nokia e61i which had its firmware failure during the updation process,,the problem is that its integrated circuit or I.C..is short circuited or what something like that..so the best option is to sent the phone to a nokia service center..i hav just sent mine..hope to get it back in a month...
Device driver problem
Grab the software directly from the Philips website at www.usasupport.philips.com - enter in your model #, click on software and drivers, then click on Device/Frimware Manager - this is a more recent version than that found on the installation CD.
Also, you can follow the FAQ process on the website which says "Player not recongized by PC"
If that fails, do a repair and a firmware upgrade:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the firmware upgrade by clicking on the update tab in Philips Device Manager. The firmware upgrade should resolve the issue permanently.
Creative Nomad Jukebox Zen Extra firmware problems on Windows Vista
Find an XP computer with WIndows Media 10 only nothing higher. If you can't find a computer like that uninstall any WMP newer than WMP 10 and then reinstall WMP 10. There is a bug in WMP 11 and its just best to avoid this until you have upgraded your firmaware to 2.x. If you don't have the newer firmware 2.x download it. Now click on the firmware  program then on your Zen Xtra select Load OS when prompt to connect the USB cable going to your computer. It should see your Zen now and should pop up that stupid window that you need to scroll at the bottom and click agree to get rid of then your Zen should reboot a few times don't touch it!! It will tell you when its done. If you can't get it to see your Zen try plugging and unplugging the USB cable. The best way is to do a fresh install of Window XP SP1 and install noting but WMP 10. You also can d/l the 1.x firmware then load it then load firmware 2.x then just agree with everything and it should work. I have upgraded and updated 6 of these Zen Xtras. Anyone that want a 120G Zen Xtra I am on Ebay: cheap-xbox-drives
I also can do upgrades to your existing Zen Xtras Players.
Top Sylvania Audio Players & Recorders Experts
Aron
 Grubhead
Grubhead
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
