Question about Garden
Need to buy a tuff torq transaxle
I need a k46ba transaxle but the price that sears wants including the tuff torq website is way ton high in price what other options do i have?
  • Garden Master
  • 2,478 Answers
Go to e-bay. Had one for $199
Posted on Mar 19, 2014
3 Suggested Answers
SOURCE: find a deflector for Craftsman Model #917.272303 also seat cover
Go to sears parts direct.donnyb60
Posted on Mar 23, 2009
  • 57 Answers
SOURCE: Can I add fluid to rear tires w/o hurting rear end.
Adding fluid to the tires should not affect the transmission at all.
Posted on May 19, 2009
What weight hydrostatic oil is recommend for tuff torq k46, and quanity
Try this site. Lots of info and pix. Site says 5w-50 synthetic oil.
1.85 liters
How to do an oil change on Tuff Torq K46 transaxle
Sep 19, 2017 | Garden
Will the transaxle from a Husqvarna GTH 2448T Hydro Gearr part # 316-0610 bolt into a Husqvarna LGT 2654 that currently has a broken axle in a Tuff Torq transaxle
Yes, the axle will fit the frame, but the pulleys and idlers will need to be set up. There is no cross reference chart so you would have to create the belt routing by trial and error. Belt length would also have to be determined.
Aug 07, 2016 | Husqvarna Garden
What tuff torque transaxle is fitted to the JD X300 mower?
The X300 used two versions K46BR and K46BC.
The X300R used the K46BD.
All three used the same seals.
Seal Kit
JD Part MIA880645 Non Stock Item
Can be order directly from
Tuff Torq PN 1A646099140
https://www.tufftorqservices.com/
Select Catalog Shop
Dec 20, 2014 | Garden
How do I check the transmission fluid level in a Cox Kingcat ride on mower What grade do I use to top it up
Depends if your has an external expansion or not. Normally you do don't need to check these transaxles as they are considered sealed units but if you wish to do so the following is the two documents from Tuff Torq on how do it.
K46 OIL 1
CAO46 External
Dec 11, 2014 | Garden
Info on repairing transmission, install belts
This transmission will be a Tuff Torq K46 series. You will need to look along the transmission's drive axle housing to get the model number. From there you can look-up the parts at Tuff Torq website under their catalog page. There is no service manuals that I know of but I did find a discussion on .tractorbynet.com about repairing the K46 that has pics. See links below:
Tuff Torq Parts Look-ups
Tuff Torq K46 Repair Guide with Pictures
As belt installation Searspartsdirect.com will have the IPL for the mower.
Nov 14, 2014 | Garden
Tuff torq k51
https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/Troubleshooting/Diagnostic_Flowchart_EN_23DEC08.pdf Hey, check out the manufacturers trouble shooting chart. This is a hydrostatic not a geared transmission right?
Apr 09, 2014 | Garden
WHAT TYPE OF OIL DO I USE ON MY TRANSAXLE MOD 917.273080
Hydrogear transaxels take a multi grade oil 20-50 the filler is a brass plug on the top, there should be a 1/4" air gap at the top to allow for expasion, Tuff Torq units also take a multi grade oil 10-30, these units normally have a resevoir on the top with upper and lower fill marks.
Dec 10, 2012 | Garden
Lawn tractor with a K57 Tuff Torq transaxle. Runs well at first but then slows down after about 10 minutes of use and then will have no power at all.
It sounds like the hyrostatic parts in the transaxle have worn to the point of failing. The alternative solutions: replace the tranaxle w/ a new one ($700-$1100 plus labor depending on exact K57 model as there are 6 sub models like K57A, K57R, K57V...etc); find and install a used compatible K57 known to work well probably run $400-600 or more; find someone that can open up your failed transaxle, diagnose which parts are worn, & replace/repair them. I've repaired the worn hydrostatic parts on my transaxle myself and it runs as good as new. It can be done. If you want to discuss having this done, email me at idakiteman at gmail dot com
Aug 22, 2011 | Garden
May 19, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
