Question about Football Fanatics St. Louis Ram jerseys : Pro Line Mens St. Louis Rams Trumaine Johnson Team Color Jersey
The on/off switch doesnt work
I cant turn on my tablet so i use the charger and now i cant turn on the tablet with the charger wat do i do
Nobis 7 internet tablet when I plug in the charger it will not charge I have checked the charger and it works and tablet won't charger just shows a battery with a exclamation mark in it
get ur battery out frm ur mobile fr 10 secs then connect charger then aftr upto 10 sec aftr that put battery back and switch on. if that doesnt work make sure the voltage of ur charger is compatible with ur phone . if still doesnt wrk maybe problm with ur port
note: sometimes the charger knob gets lose try putting it correctly
good day :)
Mar 08, 2015 | Equus Nobi Slate Tablet PC - The...
My tablet won't turn on
What is the brand name of your tablet?samsung tablets are easy to disemble. For tab 1 & tab 2 remove the back cover of the tab...do it gently otherwise you could just break it...now just remove the battery pin which is connected to pcb...if you have booster then boost up the battery then put back in tab & try to switch on the tab if doesnt turn on insert charger into port then wait for 2-3mins
Sep 07, 2014 | Tablets & eReaders
Tablet problems
You can try pressing the reset button a few times (with the charger unpluged).
if that doesnt work you can try:
Aug 14, 2014 | Visual Land Prestige 7 Internet Tablet...
NEXT BOOK WILL NOT CHARGE
there are most likely two things that are wrong with your tablet, 1. your battery is worn out or your charger/chargers might be worn out.Try plugging your tablets charger back in while its off and then turn it on. If that doesnt work then try the pinhole reset button while the charger is plugged in. Since your charger might be faulty have a professional check for shorts in the charger. if none of these work consider replacing the battery, the charger, or the tablet itsself. if this doesnt help you i apologize for wasting your time with answers that are incorrect or answers that you may have tried before.
Jul 04, 2014 | Nextbook Premium 8 Se Android
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
My tablet wont turn on or charge i have to hold the charger ina certain way and i have to keep the charger up on something
One of the wires must be broken. Get a new cord and if it still doesnt work try getting a new wall power point.
Feb 23, 2014 | Kocaso M860W 1.2GHz 4GB 8" Capacitive...
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
Power problem with Onix 7" tablet
The screen just flashess white i dont understand wat do do plz mi hopeles without it someone help me asap plz
Jan 27, 2013 | Tablets & eReaders
When i switch on the charger the both red nd green light blinks alternatly but d phone doesnt charge.. i hav also tried to chrge it using usb thru laptop..still doesnt work..done soft reset...wat to do??
Try another charger or battrey in the handset. If your handset is within warrenty you may be able to get this replaced depending on your net provider.
Hope this helps
Feb 11, 2011 | HTC HD2 Smartphone
Motorola i776 will not charge battery it says charger attached but does not charge the battery. Switched batteries works good till battery dies again.
My i776w Has the EXACT same problem... We bought a new charger, and it still doesnt work, so my dads gonna buy a new battery... The weird thing is, my sisters died at the exact same time... We dunno wats up, but its ticking me off fer sure! :P
Oct 29, 2009 | Motorola Mobility i776 Cell Phone
Football Fanatics St. Louis Ram jerseys : Pro Line Mens St. Louis Rams Trumaine Johnson Team Color Jersey Logo
62 people viewed this question
Top Football Fanatics Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Football Fanatics Golf Expert? Answer questions, earn points and help others
