Question about AudioSource EQ-100 Home Equalizer
Hooking up an equalizer to a denon avr 2807
I have done what the denon manual says as in hooking up a tape deck/recorder but it does not work
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: hooking it up!
If the amp has PreIn PreOut connections, then thats the best way to go. Home theatre amps however, have 5 InOuts, and this makes it hard. You can use the tape loop. Hook up the rec out on amp to inputs on EQ, and output of EQ to tape in an amp, then engage the tape monitor function whilst ensuring that the rec selector has the source you wish to use the EQ for.
Posted on Feb 05, 2008
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
Denon 1403/483 hooking up equalizer to it so it works
ANY analog tape deck or external processor woul go into the VCR OUT / IN pair or the CDR/Tape OUT / IN pair. Out of one device to in of the next then back.
Though not specifically addressed in the manual, I believe that operationally, ONLY ANALOG sources will go OUT to the Tape or Processor (whether or not the Tape or VCR is selected). Once you select either one of those the analog audio will be heard AFTER the external device proceeses or records it. It would be the same as Playing a tape.
However, digital sources will be disabled once the VCR or Tape is selected.
Jul 10, 2011 | Sony TC WE435 Stereo Dual Cassette Deck...
HOW can i connect this ross model eq r15s to my avr687 denon rece
Treat each EQ (or any processor) as as Tape Deck and place it on its own Tape loop on the Denon. Tape deck(s) can attach to external processors because they always have tape loops to replace the one they use.
Rule of Thumb: OUT's go to IN's.
You can have as many processors as you want. I have five.
You can serialize processors if they would logically be used together or you could get a dbx-200 or dbx-400 Program Route Selector which provides connections and switching facilities for 3 processors and 3 tape decks but uses only one tape loop on the receiver.
Individual processors can be engaged or disabled, and the whole mess can be placed in the record OR the playback end of the chain - all via front panel switches. Very versatile.
Apr 21, 2010 | Audio Players & Recorders
My denon avr-2807 sound is studdering as the
sounds like a loose cable to me probably component. trace and replace.
Chris B
PHTBA
Feb 18, 2010 | Denon AVR-2807 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Sep 28, 2008 | Denon AVR-2807 Receiver
What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Mar 15, 2008 | Denon AVR-2807 Receiver
Hooking it up!
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
AudioSource EQ-100 Home Equalizer Logo
57 people viewed this question
Top AudioSource Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
