Question about Dryers
Dryer eating clothes
Dryer is leaving black marks on clothes..eating baby clothes to shreds and tank top bras u name it. Model number its a maytag model number LDE9306ACE
It may be running way too hot. If the filter is clean there may be a thermostat issue.
Posted on Mar 19, 2014
Master_Tech
  • 770 Answers
SOURCE: dryer
nothing in the dryer i.e.crayon left in pocket?? there is no black grease used in the unit only White lithium style.. I dont think it came from the inside of the mach ...Best bet is to clean the tub out mild soap and a damp cloth it should go away. if not the peice maybe stuck in the baffles manually spin the drum do you hear anything rattling around?? Let me know
Posted on Jan 26, 2008
  • 30 Answers
SOURCE: clothes dryer
It could be rust stains coming from the tub of the dryer during the drying cycle. The only concern is that rust stains are usually brown streaks on the clothes. I'd check the to make sure there are no rust stains on the tub, check the seal of the door to make sure its still in good condition. The last possibilty could be a good cleaning of the dryer (removing lint from the lint screen compartment and the tub of the dryer).
A schematic of your dryer can be found on www3.sears.com and should show how to get into your lint screen compartment and your tub.
Posted on Mar 08, 2008
SOURCE: Tumble Dryer
how do i fit felt gasket on front of dryer?
Posted on Nov 15, 2008
  • 10865 Answers
SOURCE: My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Posted on Nov 09, 2009
SOURCE: dryer is leaving black marks on cloths.
I have the same problem. We think it is because the barrel is out of balance and the clothes are getting stuck between the barrel and the housingand the grease is causing the black marks. But I dont know how to fix that.
Posted on Jan 02, 2010
Kenmore 500 series dryer is eating clothes, clunking and leaving black marks. Clothers are getting stuck in the drum in back of dryer. Any suggestions?
It sounds that the rollers a roller went bad and or the front/rear seal now has seperated, your drum now misaligned. Depending on model.
Dec 28, 2011 | Dryers
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
My dryer drum is off kilter, eats clothes. leaves black stains on them and is making a rattling noise
The rear supports have gone bad. Part # 37001042 approx. 14.00 ea. You need to do both of them. Hope this helps and good luck.
Jan 28, 2010 | Maytag SDG3606A Gas Dryer
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
Help! black marks on white clothes w/maytag dryer
usually when this happens it's from the felt seals that are on the drum,the clothes are passing through the seal and hitting the rollers,as for other problems if the timer is bad the seals and you have a noise problem,you might just want to get a new dryer,nobody can help you without the model number and if you're gonna try to fix this you'll have to send alot more info than what you sent
Jan 02, 2018 | Maytag Dryers
My dryer squeaks and keeps eating the clothes and leaving burn marks on spots on them because it gets caught in the turn part of the dryer, it is a hotpoint electric dryer, what can cause that?
Squeaking is the rear drum bearing. The rest is the front drum slide supports. After a number of years, these wear and need replacing. Without the model number I can't give you the part numbers that fit your machine.
May 07, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
121 people viewed this question
Top Dryers Experts
